Old 01-09-2012, 10:11 PM   #1
David Lien
Question Oil Preasure Without fuel pump Rod
Help: I'am looking to buy a 59 AB engine that was rebuilt and run a couple of thousand miles with a an electric fuel pump. They left the manual fuel pump rod out. They said it had some oil preasure, and run just fine. My question to this board is would this motor still have enough oil preasure being run without the manul pump rod to prevent harm.???? thanks David
David Lien is offline   Reply With Quote
Old 01-09-2012, 10:17 PM   #2
4tford
4tford's Avatar
Default Re: Oil Preasure Without fuel pump Rod
Should be no problem
4tford is offline   Reply With Quote
Old 01-09-2012, 10:28 PM   #3
Russ/40
Russ/40's Avatar
It's probably fine. I would not put much value in the "rebuilt" claim, unless you can hear it run and do a compression check on it. Rebuilt means different things to different people. What is he asking for it?
Russ/40 is offline   Reply With Quote
Old 01-09-2012, 11:41 PM   #4
Andy
There is NO pressure lube to the rear cam bearing. There is no pressure there to lose. It has no effect on oil pressure if the rod is there or not.
Andy is offline   Reply With Quote
Old 01-10-2012, 12:45 AM   #5
David Lien
Thank you for your comments and knowledge. The motor is undervalued and has not run for a dozen years. David
Old 01-10-2012, 02:24 AM   #6
41 Fords ohio
41 Fords ohio's Avatar
Great advice. Also if it hasn't been run in that many years,I would go through it before you do all the work of installing it. Just my opinion.
When will I be old enough to know better?
41 Fords ohio is offline   Reply With Quote
