Old 06-23-2019, 06:06 PM   #1
1930artdeco
1930artdeco's Avatar
Default sediment bowl filter issue
Hi All,
I just tried to install a NAPA 3039 filter in the sediment bowl. Well the center hole would not fit around the fuel inlet so I had to widen it. When I finally got everything seated it leaked like a sieve. When I pulled it apart again the cork seemed good but the filter paper was crunched by the center fuel inlet and then it proceeded to come apart on me. And I did pull the mesh screen out. It is possible that the cork I used was for something else but just happened to fit. Either way I ordered some more just in case. What did I do wrong?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 06-24-2019, 06:28 PM   #2
old31
Default Re: sediment bowl filter issue
There isn't much that you can do wrong.
I have the same filter and it leaked like crazy because I had the gasket and metal screen in the wrong locations.
I have never seen or know how the filter paper could possibly get scrunched.
Old 06-24-2019, 08:14 PM   #3
Gary WA
Gary WA's Avatar
Why a filter in glass sediment bowl not needed if original style
www.whidbeymodelaclub.com
Old 06-24-2019, 08:36 PM   #4
Tacoma Bob
Tacoma Bob's Avatar
Been runnin the same for years with no issues. What gasket are you using?
Tacoma Bob is offline   Reply With Quote
Old 06-25-2019, 12:35 AM   #5
30 Closed Cab PU
I have no issues with using this one, the price is for an order of 2, a little more expensive, but is specifically for use on a Glass sediment bowl.
https://www.snydersantiqueauto.com/P...earchByKeyword
30 Closed Cab PU is offline   Reply With Quote
Old 06-25-2019, 09:50 AM   #6
1930artdeco
Well, since the one I got from NAPA fell apart I ordered two from Brattons along with some more cork bowl gaskets. I have no idea what I did wrong but will give it another try next week.
Mike
1957 Country Sedan
Old 06-25-2019, 06:43 PM   #7
37 Coupe
37 Coupe's Avatar
I like the ones Snyders sells better than the Bratton ones with a coil spring that has to be centered.Snyders installs easier and more reassuring.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 06-25-2019, 07:10 PM   #8
Tacoma Bob
Tacoma Bob's Avatar
I use the WIX. Pops in no springs and no issues.
