Old 06-30-2019, 08:05 PM   #1
ktgarcia
Default Starting my Pickup
I drove my 39 Pickup two weeks ago and on the way home had to pull over. I believe that was because of a vapor lock. The next day, the truck started right up and I started looking for solutions to solve the vapor lock. I know what I am going to do for that, but now my truck won't start.
I have checked electrical systems and it appears that there is no spark at the plugs.
Where should I be looking??
ktgarcia is offline   Reply With Quote
Old 06-30-2019, 08:14 PM   #2
tubman
tubman's Avatar
Default Re: Starting my Pickup
Codenser, coil, and resistor in that order.
Old 06-30-2019, 08:16 PM   #3
JSeery
JSeery's Avatar
Yep, sounds more like an electrical issue.
Old 06-30-2019, 08:18 PM   #4
WABOOM
WABOOM's Avatar
"90% of fuel problems are electrical".
I love that old phrase. It's pretty accurate. I've experienced it myself!
WABOOM is offline   Reply With Quote
Old 06-30-2019, 09:51 PM   #5
50fordcoupeman
50fordcoupeman's Avatar
Had a similar issue and it was the coil.................
50fordcoupeman is offline   Reply With Quote
Old 06-30-2019, 10:22 PM   #6
WABOOM
WABOOM's Avatar
I thought I had vapor lock when I first bought my Merc and it turned out to be the coil.
Old 07-01-2019, 09:13 AM   #7
Anteek29
Anteek29's Avatar
I've had the same problem on 2 different cars...both had intermittent coils. Grrrrr!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 07-01-2019, 01:43 PM   #8
ktgarcia
Thanks for the tips. I have a spare coil that has been rebuilt and I will go get a 6-volt condenser as a start. I appreciate the help.
Old 07-01-2019, 02:28 PM   #9
Seth Swoboda
Seth Swoboda's Avatar
You might also check the voltage going to the coil to make sure it's not getting too much voltage. In that case the coil would eventually get hot and break down.
Old 07-01-2019, 07:59 PM   #10
39portlander
39portlander's Avatar
Keeping an eye on this thread KT, let us know how you make out and have a happy 4th brother
39portlander is offline   Reply With Quote
Old 07-01-2019, 08:41 PM   #11
Tinker
Tinker's Avatar
On my 38. I use a napa IH200 condenser (I know there are better for mfg, but is easy to get. I bought 3 just because). A skip coil. A bubba dizzy. It might seem like a ad i guess, but I'm not prepared or capable of rebuilding these items with solid proficiency. It takes a village. 5 yrs running and by running I mean it sits for 4 months and cranks over quickly after that (totally rewired with harnesses from Sacramento ford). Granted new fuel lines, rebuilt carb(this was the hardest of the whole thing to source) and tank.
4v at the coil as mentioned. I've smoked a couple coils with the power on and points open without the engine running, yrs past... including a yblock. burnt into by brain now to always check if the ignition power was on when the engine was not running.
Best of luck.
