Old 04-01-2017, 06:04 PM   #1
RRW
Send a message via Yahoo to RRW
Default Sparton Horn Cover Plate rivets question....
I received my Sparton horn cover plate in the mail today and the two included rivets are the split style.
I was expecting pop rivets for my Arrow pop riveter.
Do all suppliers ship their covers with split rivets?
What have 'others' on the Fordbarn used to attach the plate?
RRW is offline   Reply With Quote
Old 04-01-2017, 06:19 PM   #2
RonC
RonC's Avatar
Default Re: Sparton Horn Cover Plate rivets question....
Split rivets are what you want
RonC is offline   Reply With Quote
Old 04-01-2017, 06:33 PM   #3
RRW
Thanks for your reply.
However, just how do I get a 'tight' attachment as a pop rivet would?
I did start to try a long straight slot screwdriver but quit B4 I thought
I might mess up the rivet.
Old 04-01-2017, 06:39 PM   #4
Afordman31
Afordman31's Avatar
I used a piece of nylon to back up the head of the rivet then after spreading the rivet I tapped it with a small hammer.
I believe the tag should be mounted so you can read it from the front of the car.
Afordman31 is offline   Reply With Quote
Old 04-01-2017, 07:47 PM   #5
RRW
RonC and Afordman31,
Thanks for the info.
After I spread the rivet I used a clamp with a plastic cap on the outside of the cover
and was able to cinch up the rivet head flush/tight to the cover plate by flattening the legs inside the cover.
It looks very nice.
Old 04-01-2017, 10:32 PM   #6
cpf240
cpf240's Avatar
Would you please post some pictures of this? Once picture uploading is working again, of course... I'll be doing this sometime in the near future as well... Thanks!
cpf240 is offline   Reply With Quote
Old 04-02-2017, 05:13 AM   #7
harleytoprock
Which supplier sells the correct split rivets for the Sparton horn tag?
harleytoprock is offline   Reply With Quote
Old 04-02-2017, 07:49 AM   #8
Boston Bruce
Boston Bruce's Avatar
I got mine from A&L in CT.
Boston Bruce is offline   Reply With Quote
Old 04-02-2017, 08:10 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
X2, and you can also have A&L stamp the numbers in the plate.
Old 04-02-2017, 08:45 AM   #10
RRW
I got mine from Sammy at AZ Model A
Ph 480-782-0266
