Old 03-29-2017, 06:23 AM   #1
JohnB15632
JohnB15632's Avatar
Default 31 Model A SW Town Sedan Front Seat Restoration
I am restoring the front seat on my 31 Town Sedan.
I have the wood frame for the front cushion.
I do not have the wood frame for the front backrest
I can not located the wood frame for the front backrest. It is not listed on any of the suppliers websites.
Does there exist a wood from for the front backrest.
How is the backrest connected to the metal seat?
Thanks,
JohnB15632 is offline   Reply With Quote
Old 03-29-2017, 10:23 AM   #2
duke36
Default Re: 31 Model A SW Town Sedan Front Seat Restoration
don't recall back wood frame, just tack strip on seat back top, 1 vertical wood strip @ each vertical side inside edges and wood horiz.tack strip via holes in lower photo. Perhaps 2 wood cross braces missing on seat bottom frame ?
duke36 is offline   Reply With Quote
Old 03-29-2017, 12:17 PM   #3
davehc
davehc's Avatar
Found this one pic on Google images , says 30/31 front seat . Also a couple pics of my 30 Briggs TS front seat after I recently put some aftermarket covers on it . Wood strip up the ends , and what feels like about a 1" square strip across the bottom for tacking . didnt have all the padding / material off , so not sure what the top is like . Hope it helps .
davehc is offline   Reply With Quote
Old 03-29-2017, 01:42 PM   #4
JohnB15632
JohnB15632's Avatar
Thank you. This picture sure does help.
Old 03-30-2017, 08:09 AM   #5
Terry, NJ
Terry, NJ's Avatar
John, I restored one of these. See the pictures in my album "My A". I made one extra of these frames and I have it for sale, same model of seat. There are three, see Snyders catalog, in the seat section.
Terry
Terry, NJ is offline   Reply With Quote
Old 05-25-2024, 11:53 AM   #6
Mikes A
I am having the same issue. Did you find the solution?? I thought I lost the wood piece(s) that holds the springs in place? Someone said there are just straps that are tacked to the tack strip that hold the springs in place ? Maybe someone will post some pictures. Also a picture of the correct springs would help
Mikes A is offline   Reply With Quote
Old 05-30-2024, 07:08 AM   #7
jwmckenzie
Mike, check out this thread.
https://fordbarn.com/forum/showthrea...nt+window+seat
jwmckenzie is offline   Reply With Quote
