11-15-2015, 03:41 PM | #1 |
What are these 'running boards' for?
SOLID thick cast aluminum. Ford script. I tried to find out years ago with no luck.
11-15-2015, 05:17 PM | #2 |
Re: What are these 'running boards' for?
1913-1925 model T
11-15-2015, 06:56 PM | #3 |
All running boards for Model T were I thought steel.
I'd like to learn otherwise if aluminum ones existed. |
11-16-2015, 12:43 AM | #4 |
Would be relatively easy to sand cast a set using original steel T boards as the pattern. If they are a lot thicker, which would be necessary, perhaps a layer of plywood or other material was bonded to the 'pattern' prior to the casting process. You may have the product of an early reproduction parts business or some 'one off' pieces.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-16-2015, 01:27 AM | #5 |
