Old 09-25-2013, 08:42 PM   #1
Dennis Mielke
Default 33/34 Garwood Fender skirts
Need help on how the top of the skirt fastens to the fender.
Thanks,
Dennis
Dennis Mielke is offline   Reply With Quote
Old 09-26-2013, 01:30 AM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 33/34 Garwood Fender skirts
There yi go Dennis
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 09-27-2013, 12:55 PM   #3
Dennis Mielke
Does it just grab the inside top edge of the fender bead? It doesn't seem very secure.
If so it would seem that it would jiggle loose when the car goes over bumps.
Old 09-27-2013, 01:06 PM   #4
Vic Piano
Vic Piano's Avatar
The horizontal rod at the bottom of the skirt, when pushed up, brings the curved part at the top down into the fender bead. The rod is usually secured by a "lip" on the bottom edge of the skirt. Also, the tabs on the edge of the skirt in the front and back, rest against the finder lip. Some have additional brackets that are screwed into the fender lip on the bottom.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-27-2013, 11:18 PM   #5
Dennis Mielke
Ted, Vic,
Thanks for the quick help......
Dennis
