04-13-2018, 06:29 AM | #21 | |
Re: odd type of radiator
I have however just received in the mail today, an electronic thermometer. Haven't put it on the A yet but checked out the beer in my fridge and that's 4 degrees Celsius. |
04-13-2018, 02:14 PM | #22 |
hi Jack. your comment is interesting. I would be pleased to hear your comments as to why the 2 blader is more efficient. I am uncertain on the 5 blader I purchased.
the diameter of the fan is 14 inches and each blade is only 4 inches. that is 6 inches of hub. the large hub doesn't have the speed of the blades and thus if blades would not pull the air. it does however tend to obstruct the airflow. I would welcome comments from others. with thanks, gary |
04-13-2018, 04:25 PM | #23 | |
I believe you have to consider the era that Ford designed, built and sold the Model A., e.g., bad roads, very little traffic, low speeds, short trips, etc. You also have to consider the environment, for example, in inland Southern California, much like Australia, we have sustained temperatures of over 100 to 110 degrees during summer. My main problem is climbing the long hills to get to my house with a stock engine and transmission (no OD). I could do it easily at 20 - 25 mph but the traffic conditions require me to push it up to 50 mph which puts a strain on the engine and cooling system. David Serrano |
