Old 09-21-2020, 04:19 PM   #1
Joe/Ct
Joe/Ct's Avatar
Default Rear Spring Installation
I recently did some work on my drive train and did so by removing the rear end, spring and all. I removed the spring to make some repairs, and have mated the spring to the rear end. I am now in the process of re-installing, but am having some difficulty. The spring fits into the channel and I am ably to tighten the nuts to the original u-bolts, but I am unable to do so enough to insert the cotter pins. I have checked to ensure that the spring bolt is in the frame hole, but still no joy. Any suggestions? As a side note, others have recommended that I should have left the spring in and just removed the rear end at the shackles, but I am beyond that. One option is to remove the spring from the rear end, install just the spring, and then install the rear end with the spring already installed.
Joe/Ct
"The older I get, the better I was"
Joe/Ct is offline   Reply With Quote
Old 09-21-2020, 04:20 PM   #2
Joe/Ct
Joe/Ct's Avatar
Default Re: Rear Spring Installation
I should note that this was on our 1928 roadster, and we did use one of the safe spring removers.
Joe/Ct
Old 09-21-2020, 04:55 PM   #3
Tacoma Bob
Tacoma Bob's Avatar
MMMM Perhaps lower the car with wheels installed. The weight with the car on the ground may the difference.
Tacoma Bob is offline   Reply With Quote
Old 09-21-2020, 05:28 PM   #4
Russ/40
Russ/40's Avatar
Did you change or remove the top spring leaf?
Old 09-21-2020, 05:51 PM   #5
1930-Pickup
Are you using the spring clamps for the 7 leaf spring?
Different leaf counts require different clamps.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-21-2020, 05:59 PM   #6
Tom Endy
Tom Endy's Avatar
Make sure that the square head on the center bolt is correctly located inside the square hole in the frame section. Be careful with a rear spring attached to a rear axle assembly outside of the car under tension. If the head of the center bolt pops off It can be lethal.
Tom Endy
Old 09-21-2020, 07:26 PM   #7
Patrick L.
Patrick L.'s Avatar
Have you added an extra leaf ?
Is the center bolt tight ?
Is the square of the center bolt head protruding thru the crossmember hole ?
Old 09-21-2020, 08:18 PM   #8
katy
katy's Avatar
How much are they out? Got a picture?
Old 09-21-2020, 08:21 PM   #9
Joe/Ct
Joe/Ct's Avatar
No I did not. The only work that I did was in the torque tube. The springs, u-bolts and nuts were as original.
Joe/Ct
Old 09-21-2020, 08:22 PM   #10
Joe/Ct
Joe/Ct's Avatar
I changes nothing on the spring.
Joe/Ct
Old 09-21-2020, 08:23 PM   #11
Joe/Ct
Joe/Ct's Avatar
Tom Endy
Yes, the square head is in the square hole.
Joe/Ct
Old 09-21-2020, 08:24 PM   #12
Joe/Ct
Joe/Ct's Avatar
I am out by 1/4" all 4 bolts....
Joe/Ct
Old 09-21-2020, 08:26 PM   #13
Joe/Ct
Joe/Ct's Avatar
I changed nothing on the spring and, yes, the center bolt is tight...
Joe/Ct
Old 09-21-2020, 08:30 PM   #14
katy
katy's Avatar
Maybe you have the spring clips upside down?
Old 09-21-2020, 08:47 PM   #15
Big hammer
Just about the thickness of the square head of the bolt not aligned with the square hole in the cross member. It's happened to me.
get a bigger hammer tap done
Old 09-21-2020, 10:08 PM   #16
Joe/Ct
Joe/Ct's Avatar
I don't think so...do you have a pic how they are to be installed?
Joe/Ct
Old 09-22-2020, 11:16 AM   #17
Bob C
Are the tabs on the u-bolts in the holes on the cross member?
Old 09-23-2020, 09:35 PM   #18
Joe/Ct
Joe/Ct's Avatar
Yup. I am using the spring clips that were originally on the car. All I did was remove the drive train, including the spring. I then removed the spring from the axles to make it easy to repair the drive shaft. I reinstalled the spring, inserted in the vehicle and used the original spring clips. Unfortunately, I was unable to tighten the nuts enough to insert the cotter pins.
Note that Andrews recommends removing the the rear end with the spring attached while some of the guys at the shop suggest leaving the spring on the vehicle and removing the shackles.
Joe/Ct
Old 09-24-2020, 08:24 AM   #19
rocket1
Just a thought as the spring flexes it wears a groove into the leaf below it,if you have no weight on the spring while trying to tighten the spring clips possibly the leaves are resting on the unworn or high spots,lower the back of the car to the ground and or have a couple of people sit in the back and then see if you can tighten those nuts the xtra 1/4 inch.
rocket1 is offline   Reply With Quote
Old 09-24-2020, 11:50 AM   #20
rotorwrench
rotorwrench's Avatar
It usually is easier to remove the rear axle with the spring installed but it also depends on what else is disassembled during the whole repair process. Removing the spring from the rear axle is not normally a big deal but it would be easy to reinstall it 180 degrees from where it was originally and that might have changed the fit just enough so that things aren't seating like they were before. A person needs to confirm that the spring is seated all the way and that those U-bolts are also seated as they should be.
If the spring was not disassembled then it should not affect fit other than the way it seats into the cross member.
