Old 02-20-2018, 02:52 PM   #1
daveymc29
daveymc29's Avatar
Default Any clues on light switch stiffness?
I am rewiring one of my A's. The switch would seldom turn (in the center of the steering wheel) and the few times I got it to move it blew a fuse or tripped my breaker. Before installing the new wiring harness I tried the new harness with the old switch and though it moves better it isn't a whole lot better than the old one. The new wires look more intact and I turned the lower bushing on the steering gear so that now the bail locks the switch from the bottom instead of the top. (Turned the bushing so the slot for the switch is on the bottom, it had been on top.) Just wondering if anyone else has suffered with a stiff switch and how they got it to loosen up? Lube, what kind and where did you put it, it you did? With the switch removed the light and horn rod spins freely and doesn't appear to be the wrong length or bent in any way.
daveymc29 is offline   Reply With Quote
Old 02-20-2018, 03:50 PM   #2
slammin
slammin's Avatar
Default Re: Any clues on light switch stiffness?
Are you using original parts or repros? The plastic piece that hold the contacts on the repro wire loom is about .025 too thick. On mine the contacts were not flush, adding to the problem. You can belt sand the lower piece where to mates to the upper piece. Using dielectric grease will help, too.
slammin is offline   Reply With Quote
