02-19-2018, 08:53 PM | #21 | |
Re: Tappets?
What is the actual base diameter of the tappets that you bought ? When you mention the "stock ones" are they the non adjustable type ? What type of cam are you using; original;reground,new Stype performance cam ? |
02-20-2018, 03:40 AM | #22 |
Re: Tappets?
It depends on the opening and closing ramps for the cam lobes. You could put a thin coat of blueing on the tappet base, then roll the cam around and check to see if the blueing got scraped off the edge of the tappets.
I bought a set of adjjustable tappets several years ago, and they are still in the blister pack, but I have a feeling they are also the small diameter ones. |
02-21-2018, 01:14 AM | #23 | |
Re: Tappets?
Tom, I will try the bluing test tomorrow and post results. |
02-21-2018, 12:09 PM | #24 |
Re: Tappets?
The stock lifter is 1.110--1.125. That is a lot of tolerance. As I recall, the so called double lock lifters are .998, and the single lock friction fit are 1.118.
02-21-2018, 12:16 PM | #25 |
Re: Tappets?
They should be OK with a stock cam, but going to church wouldn't be a bad idea.
