05-28-2017, 08:46 PM | #21 | |
Re: 35 ford coupe replacement front shock?
05-29-2017, 01:24 PM | #22 |
There are a pair of THESE on eBay right now. Listed so that you can "BUY IT NOW" for $50! Click the link below for the eBay listing! DD
http://www.ebay.com/itm/1947-1948-FO...3D361976988744 |
05-29-2017, 02:32 PM | #23 |
V8 COOPMAN- Will the NOS 47/48 shock mounts work if you just want to convert the shocks from Houd to tube type shocks on a standard suspension setup ?
Lineman, the only dumb animal that can harness himself !! |
05-29-2017, 03:11 PM | #24 |
Within reason.........YES! Keep in mind that any time we use the word "convert", some modification and re-work is usually involved. The whole idea here is to get the UPPER mount for the tube shock elevated to a point that a reasonable-length tube shock can be safely and efficiently mounted. The '47-'48 mount MAY necessitate SOME mods in mounting to effectively afford the correct geometry for the situation (since this is NOT a '47-'48 Ford), or the particular car being modified. DD
06-28-2017, 05:57 PM | #25 | |
When I look at what I believe are my original perch bolts and the thought of removing them with everything still attached, I get beyond concerned and question doing this. Has anyone installed these with good results ? ..... Thanks
06-28-2017, 07:54 PM | #26 |
06-29-2017, 12:49 AM | #27 |
I found some used old ones thanks to coopman and they bolted right in. No issues what so ever.
06-29-2017, 04:36 AM | #28 |
Solo, can you show me a picture of where your shocks bolt up on the bottom ?. Thanks
06-29-2017, 07:10 AM | #29 |
For the folks that like the photos upright.
06-29-2017, 10:38 AM | #30 |
Here are a couple pictures Solo posted on an earlier thread on these shocks. Don't know if these are trimmed '35-'36 perch bolts or later bolts. Also have seen the dual eye perch bolts from the later '40's used with tube shocks. Many of the ones I have seen had shock studs that fit the taper in perch bolt eye.
06-29-2017, 02:25 PM | #31 | |
06-29-2017, 07:27 PM | #32 |
07-01-2017, 05:17 PM | #33 |
If you're okay with aftermarket, Chassis Engineering makes a tube shock conversion kit for your car. They use an extended shackle bolt as a lower locating point for their shock. The upright is strong, it bolts on in two planes.
CE makes good stuff, been doing it for years. P/N is AR-2037 You'll have to disassemble your spring and shackles again to install.
Seabright Hot Rods |
