Old 10-29-2019, 07:26 PM   #1
rfitzpatrick
Default Steering Wobble
New Spindles, Shocks, Tires (balanced), F-150 Steering, Brakes -- and it just started with this wobble -- so what did I forget, and yes, I rechecked my front wheel bearing - again.
What am I over-looking PLZ -- what a disappointment this is. It's a '31 PicUp
Tires about 12 months, rest of work last 4 months
Thanks Guys
rfitzpatrick is offline   Reply With Quote
Old 10-29-2019, 07:36 PM   #2
dbaldwi3
dbaldwi3's Avatar
Default Re: Steering Wobble
Did you look at front radius ball? I was told this can cause wobble.
dbaldwi3 is offline   Reply With Quote
Old 10-29-2019, 08:07 PM   #3
wmws
Did you check your toe in and caster. Toe in should be about 1/16 inch and caster I believe about 5 degrees.
wmws is offline   Reply With Quote
Old 10-29-2019, 08:10 PM   #4
Patrick L.
Patrick L.'s Avatar
There is something loose. It can be anything between the wheel bearings back thru to the steering box adjustment. Also the toe-in should be 1/16".
Old 10-30-2019, 08:43 AM   #5
rfitzpatrick
OK, took the nose tires off and compared them -- drivers has a very slight wear on the out-most tread --would this be "toe-in"? Also I said spindles what I meant was King-Pins. Does this change your opnion? I do have Club-Support, but sometimes I'd like to figure things out myself?
Thanks Guys
Old 10-30-2019, 09:36 AM   #6
Tacoma Bob
Tacoma Bob's Avatar
Long story short. In my case after screwing with everything imaginable check your spring perch nuts. It was a last resort for me. Drivers side took two full turns and pass. side 3/4 of a turn. Problem solved. Patrick L. nailed it.
Tacoma Bob is offline   Reply With Quote
Old 10-30-2019, 10:43 AM   #7
katy
katy's Avatar
Ditto
Old 10-30-2019, 02:58 PM   #8
Patrick L.
Patrick L.'s Avatar
Kinda thought you meant king pins.
The tire wear can be camber [ excessive camber is normal for old cars] or improper toe setting. Old cars tend to have a lot of caster too, but, thats not your problem.
Look for something loose first, there is a lot to look at.
Old 10-30-2019, 03:29 PM   #9
1931 flamingo
1931 flamingo's Avatar
What kind/brand/size tires?? Air pressure?? Tie rod ends good?? Steering box tight to the frame?? Pitman arm tight to the steering box?? Balls on the spindles round?? Toe in??
Paul in CT
Old 10-30-2019, 04:26 PM   #10
Werner
Werner's Avatar
Fitzpatrick, my roadster also had this problem.
It gots better when I increased the tire pressure to >2.6 bar. But that was not good enough.
I've found the real problem: The pan that is sitting on the center ball cup for the front axle triangle (under the car approximately in the middle, don't know the exakt name; see picture) had too much play.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 10-30-2019, 05:37 PM   #11
dbaldwi3
dbaldwi3's Avatar
Radius ball
Old 10-30-2019, 05:44 PM   #12
Werner
Werner's Avatar
Thanks for this language hint!
Werner
Citroen 11 CV, 1947
Old 10-30-2019, 06:28 PM   #13
rfitzpatrick
I have hip-arthritis -- getting under the PicUp requires two days out from under the Piczup to recover--right now, am checking the spring pearches per a previous post. Found nothing Passengners side today -- Thanks
Old 11-07-2019, 05:05 PM   #14
rfitzpatrick
Steering Wobble Update: After contacting Mel Gross about my steering box -- he e-mailed me the adjustment instructions. Our club mechanic and I were able to correct my problem in about ten minutes, fifteen if you include clean-up time. Also didn't realize how loose my steering had become -- there's a lot of confidence driving my PicUp when my steering and brakes are in top shape
Old 11-07-2019, 05:46 PM   #15
Tacoma Bob
Tacoma Bob's Avatar
HOOORAY!. Randy is a saint. My issues drove me crazy and after going through 95% of everything known to man.................Spring perch nuts. Glad you got it sorted out!!
Old 11-08-2019, 07:51 AM   #16
History
History's Avatar
Here's something that would help IF you had the car/truck on jack stands.
https://m.youtube.com/watch?v=qcVVcIj879Y
History is offline   Reply With Quote
