07-24-2012, 10:08 AM | #1 |
37 V8 intake manifold HELP
I just got a original aluminum manifold for my 37 ford flthead V8. Everything is the same as my cast iron manifold except where the fuel pump breather bolts on, It is 1" lower then the cast one. What do I have to do to use it? Did I buy one that won't fit? Thanks Ron
07-24-2012, 10:16 AM | #2 |
Re: 37 V8 intake manifold HELP
Use the 1" shorter fuel pump pushrod. It'll fit! DD
07-24-2012, 10:31 AM | #3 |
Also use the 4 inch oil baffle tube instead of the 5 inch that you have now.
07-24-2012, 11:06 AM | #4 |
These forums are great and really work. Thanks for the help!
07-24-2012, 11:09 AM | #5 |
Check your PM's. ken ct.
07-24-2012, 04:37 PM | #6 |
www.fordcollector.com |
07-24-2012, 09:21 PM | #7 |
Or shine up the aluminum intake and run an electric pump if you have vapour lock problems. ..B.
07-25-2012, 02:01 PM | #8 |
07-25-2012, 02:27 PM | #9 |
Or make a spacer to raise the pump to ci specs. Best of both worlds.
I dig coal, which provides motivation for EVs. |
