Old 09-22-2020, 12:02 AM   #1
STAN WHITE
Default starter solinoid
Question, I mounted a starter Solinoid on the firewall with two sheet metal screws. Does it require a clean metal surface for a ground? Thanks Stan
STAN WHITE is offline   Reply With Quote
Old 09-22-2020, 04:51 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: starter solinoid
Normally any (if) needed ground will occur between the screws and the bare metal solenoid case.
After installation check continuity between solenoid case and engine.
Old 09-22-2020, 10:35 AM   #3
Bob C
Depends on what solenoid you are using. The original Ford solenoid grounded
through the start button and does not require a grounded base.
Old 09-22-2020, 12:31 PM   #4
Kube
Kube's Avatar
No, it does not.
Old 09-22-2020, 12:35 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Kube View Post
No, it does not.
BUT.....the starter button on the instrument panel DOES require a good bonding (GROUND) to the instrument panel (or chassis ground) itself! That Kube guy in the post just above has been known to solder a separate (hidden) ground wire to his starter buttons. DD
Click Links Below __
T5 W/TORQUE TUBE
