09-11-2019, 06:55 AM | #1 |
Jumper wire
I got a problem somewhere. The car quit running with the popout switch. I took it out and had it tested. It tested out as perfect. So I put a jumper from coil to the condenser on the side of dizzy. Car runs fine that way. Then if you turn key off engine stops. Turn key on will start rt up. Disconect jumper will not run. So what you think problem might be? T. I. A. RAY
09-11-2019, 07:19 AM | #2 |
Re: Jumper wire
The wire from the switch to the dist is shorted to ground.
09-11-2019, 07:50 AM | #3 |
Re: Jumper wire
I assume your "jumpering" is being done with the Electroswitch in place - as in normal?
And when you turn the key off (push in) Electrosw grounds the live circuit? Um - that is what it is supposed to do and indicates the armor cable and that part of the switch action is ok. Electroswitch is set up to make the center cable "live" on pop-out and "grounded" on push-in/lock. What may not be ok is the contact in the switch which makes the center wire "live." You may have an issue with the wiring feeding the Electroswitch. Check out the wiring diagram at https://lesmodela.files.wordpress.co...ng-diagram.pdf The red wire is what I would look at. Joe K
Shudda kept the horse. Last edited by Joe K; 09-11-2019 at 08:04 AM. |
09-11-2019, 08:16 AM | #4 |
Re: Jumper wire
perhaps the lower plate shorts when the popout is screwed in, many repros are made with thinner metal that distorts easy
09-11-2019, 09:35 AM | #5 | |
Re: Jumper wire
09-11-2019, 10:20 AM | #6 | |
Re: Jumper wire
TerryO |
09-11-2019, 11:37 AM | #7 |
Re: Jumper wire
I'm definitely not an electrician, but always thought the stock ignition was set to ground the points, thru the armored cable, when ignition key is turned on, and there was power to the points from the coil at all times. If so, your existing wire from the coil to the points has an 'open' in it. Replace the stock wire and all should be normal. Note: I don't wire my A's like that so I could be mistaken???
09-11-2019, 08:48 PM | #8 |
Re: Jumper wire
Look at the wiring diagram and you will see that if the switch and the wire in the armored cable has tested good then it has to be the red wire open or a loose connection in the terminal box. By installing a jumper wire you are bypassing the red wire, the switch and the wire in the armored cable until the pop-out switch grounds the circuit and kills the ignition.
TerryO |
09-12-2019, 11:02 AM | #9 |
Re: Jumper wire
Jumper wire update Seems like the popout ign. switch was indeed bad after it was deemed ok. There is a small contact inside the back cover that was intermittent . So all is well so far. Going to change the popout with a on off one from the vendors Thanks for all the responses. On guy hit it on the head RAY
09-12-2019, 01:47 PM | #10 |
Re: Jumper wire
My cars are not point show cars . I have always avoided the pop out switches for fear of problems that would be difficult to get to . I do use the armored cable through the terminal box just for an original look . I use a look alike aftermarket switch .
