Old 06-13-2017, 03:17 PM   #1
Tod
Default 5 main blocks
I am ready to cast some 5 main blocks with designed cores specifically for them. The core shop requires a minimum of 7 sets, so I need a few people interested to let me know if they are ready for one. I probably have a couple of people already but need to know for sure.
Tod
Tod is offline   Reply With Quote
Old 06-13-2017, 05:18 PM   #2
Crazydaddyo
Crazydaddyo's Avatar
Default Re: 5 main blocks
I want one, maybe 2. need details and cost. I sent a PM through facebook.
Crazydaddyo is offline   Reply With Quote
Old 06-13-2017, 06:32 PM   #3
waxhead
waxhead's Avatar
Aluminium or iron??
waxhead is offline   Reply With Quote
Old 06-13-2017, 08:14 PM   #4
Chris Haynes
Chris Haynes's Avatar
What crank fits them? Pressure oil? Will the outside pass for OEM? And most of all, price.
TIA,
Chris
1921 Runabout
1930 Tudor
Early 1930 AA
Old 06-13-2017, 11:15 PM   #5
daveymc29
daveymc29's Avatar
If someone like AER is building a long block from your casting I can find a customer tomorrow for a finished product. I'm not trying to change the subject here, just saying I can get a customer for the finished product. Of course the rest is in your hands. Thanks for a response if that is available. I'm sure if the long block is $6K or less he'll be in. (As would many others.) JMHO
daveymc29 is offline   Reply With Quote
Old 06-14-2017, 05:20 AM   #6
Tod
Originally Posted by waxhead View Post
Aluminium or iron??
Iron. I can do aluminum if you want that.
Tod
Old 06-14-2017, 05:21 AM   #7
Tod
If you can sell long blocks I can get you pricing on those.
Tod
Old 06-14-2017, 05:24 AM   #8
Tod
TIA,
Chris
WE will have to get with Scat for cranks. Full pressure oil. There is a block running on YouTube. Have a look. The 5 main block will be in the low-to-mid 2k range.
Tod
Old 06-14-2017, 08:36 AM   #9
Ray64
Ray64's Avatar
Tod what is the LINK for the running block
Ray64 is offline   Reply With Quote
Old 06-14-2017, 09:21 AM   #10
daveymc29
daveymc29's Avatar
I'm not a vendor, just have a friend whose engine scattered and today will see what he intends to do. We're both in our 80's so not doing our own work, He seemed to like the idea of a "New" block last night If you already have a price on the long block fine, but don't waste any time on me if you don't. It will only be one at this point,
Old 06-14-2017, 11:32 AM   #11
hardtimes
hardtimes's Avatar
Tod
Hey Tod,
As you are aware, from day one, I have indicated that I will take/buy the first 5x5 (cam bearing/crank bearing) iron block. Nothing has changed in my position.
We also have discussed the OHV specific block, which would enable you to enlarge cooling capacity of block. Maybe this is too far off regular production block now ?
Thanks for your progress on this project for us !
A bit off block topic, is the OHV head going to be ready for use on the 5x5 block ?
Old 06-14-2017, 02:55 PM   #12
Tod
Originally Posted by hardtimes View Post
Hey Tod,
Rick,
I did not count you out. The OHV core models are at the core shop. It is moving ahead. I was working on tools for the aluminum block of yours today. Things are moving, even if slowly.
Tod
Old 06-14-2017, 02:56 PM   #13
Tod
Prus Jr. and Sr. are about 8-9 miles from my shop. Either could build you one.
Tod
Old 06-14-2017, 02:57 PM   #14
Tod
https://www.youtube.com/watch?v=dhVs...ature=youtu.be
Tod
Old 06-14-2017, 06:27 PM   #15
AL in NY
AL in NY's Avatar
What main bearing set is the block machined for? Any idea the cost of the SCAT crank?
AL in NY
AL in NY is offline   Reply With Quote
Old 06-14-2017, 07:20 PM   #16
Tod
We are working on getting pricing. Whoever finish machines the blocks will put in the bearings.
Tod
Old 06-15-2017, 01:12 AM   #17
Crazydaddyo
With the Model B spacing on the main bolts, the best bearings to use are SB Chevy rod bearings. They are 2.125" dia.
Old 06-15-2017, 12:18 PM   #18
hardtimes
hardtimes's Avatar
Hey Dan,
Good suggestion !
I believe that Donavan alum four cyl blocks make use of these rod bearings as well as other readily available chev parts. Donavan also had his 5 main cranks made by a well known crank maker. I believe that those would also / could also be used in the Tod 5 main block, and they already have the specs/drawings on file.
Old 06-15-2017, 02:42 PM   #19
Tod
I was told Scat cranks will be about $2700.
Tod
Old 06-15-2017, 02:47 PM   #20
Tod
Hey Dan,
Good suggestion !
I was talking with a guy today about maybe making a cast 5 main crank. His opinion is that, given the low horsepower of these engines, a cast crank would work just fine. He is a builder.
An advantage to me making my own 5 main crank is that it can also be used in the 3 main applications. Be nice to make a very affordable crank.
Tod
