Old 01-30-2018, 03:39 PM   #141
FRANK PKNY
FRANK PKNY's Avatar
Default Re: Rare '40 convertible restoration project
Beautiful work, your a top shelf restorer. Thanks for the spare tire post. Frank PKNY
FRANK PKNY is offline   Reply With Quote
Old 02-01-2018, 09:12 PM   #142
Kube
Kube's Avatar
Originally Posted by sidevalve8ba View Post
Mike,
I am sure you have been asked this a hundred times but I'll ask once more; what paint do you use on the frame and suspension? Thanks.
Hi Ted,
I'm sorry I didn't address this sooner. Sometimes I seem to get scattered.
On the frames and miscellaneous chassis parts I use Mason (brand) single stage gloss black enamel. It holds up very well and provides a deep gloss.
I would not use this on a body panel...
If I recall, it's about $300 or so per gallon.
Old 02-01-2018, 09:12 PM   #143
Kube
Kube's Avatar
Thanks Frank
Old 02-13-2018, 08:28 PM   #144
Kube
Kube's Avatar
Great news for me anyway... I'll get the back half of the body painted tomorrow. I'll probably do the front half Thursday.
I also managed to install the transmission / engine assembly to the chassis today.
Old 02-13-2018, 09:44 PM   #145
flatford8
flatford8's Avatar
I don’t see the pictures......I know you wouldn’t post a “progress report” without pictures......right?????.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 02-14-2018, 08:09 AM   #146
Kube
Kube's Avatar
Hey Mark, You are 100% correct. I can no longer seem to upload photos. I have asked Ryan what may be the cause.
I start painting in a few hours
Old 02-14-2018, 10:42 AM   #147
funrunr
funrunr's Avatar
delete
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 02-16-2018, 05:02 PM   #148
Kube
Kube's Avatar
Finally I've figured out the photo posting issue. Pretty good for a guy who is for the most part camera ignorant.
Anyway, the body is now painted. Monday I'll start wet sanding. That's a time consuming task as most of you realize. I'll go to at least 3500 grit prior to buffing.
This project is finally coming together!
Old 02-16-2018, 09:47 PM   #149
Bill
Bill's Avatar
You have never mentioned that you have any help in your shop. Do you have any assistance? Bill
Bill is offline   Reply With Quote
Old 02-17-2018, 02:09 PM   #150
Kube
Kube's Avatar
As I have become older, I have slowly (read: stubborn) accepted the fact I simply can't do it all... at least not as quickly as I once could.
Thus, when I need help, I am not fearful of asking
Old 02-18-2018, 12:32 AM   #151
35fordtn
35fordtn's Avatar
Mike looks excellent!! In regards to a mercury in a ford... is the transmission case a mercury case re-stamped with a ford number?
Old 02-18-2018, 01:40 AM   #152
Tinker
Tinker's Avatar
Mike, your process is unmatched and a pleasure to see.
Old 02-18-2018, 08:24 AM   #153
Kube
Kube's Avatar
Nope, it's a "regular ol' Ford" transmission.
Old 03-12-2018, 07:13 PM   #154
Kube
Kube's Avatar
Dropped the body down today. I am so happy
I hope to pull the jig out tomorrow and start assembling.
Old 03-13-2018, 08:54 AM   #155
DD931
DD931's Avatar
Mike - I'm getting dehydrated from drooling so much!!
DD931 is offline   Reply With Quote
Old 03-13-2018, 08:31 PM   #156
Kube
Kube's Avatar
I had a blast today! This is the fun part- when it finally starts going together. Now for certain there are not enough hours in the day! I don't want to stop...
Today was spent primarily on the inside of the body. I insulate any areas that will not be seen once the car is assembled. Although this car will most likely never be (road) driven, just in case it does - the insulation makes a huge difference in canceling road noise.
Old 03-13-2018, 10:15 PM   #157
DavidG
DavidG's Avatar
Heresy!
Old 03-13-2018, 11:13 PM   #158
deuce_roadster
deuce_roadster's Avatar
Mike, what color is this car? I can't tell if it is black, Lyon blue or maybe dark green. Maybe my monitor just doesn't show it well enough to tell.
I would say like the others, it meets your high expectations!
Old 03-14-2018, 07:36 AM   #159
Kube
Kube's Avatar
I am far from anything that could be described as a photographer. It's Lyon Blue.
Old 03-24-2018, 10:04 AM   #160
Kube
Kube's Avatar
Still at it guys! Time, as you all know, is the rarest of commodities. Regardless, I'm making decent progress I suppose.
The doors should be painted very soon. I'll install them and do any final minor alignment that may be necessary and then start to install the top.
In the meantime, I'll complete the dash, etc. installation. Most of the work "beneath the hood" is done.
