10-08-2017, 06:21 PM | #1 |
Dilemma in my 29 motor resurection
Well, my plans to just "run it" on my '29 motor with unknown history have finally come to a more sensible plan. My dad and I got it running and it runs and sounds great, thanks to this board! Guy I bought it from found it in a barn in Riverside , Ca and just wanted the body for a hotrod..so I bought the rest. Did all the standard "de-mothball an old engine stuff" and feel really lucky to have a solid, what appears to be, rebuilt motor. I decided to pull it and check the mains, rods and put a head on it, paint block, etc... I had soaked the block a few days with Evaporust, but today finally got the Head off (after 5 hrs of work ) and find all the water passages clogged with who the hell knows what? Is it from a mouse or something, there is weird stuff in there and what should I do to flush it out? Plastic, wood, rust, etc..
10-08-2017, 07:16 PM | #2 |
Re: Dilemma in my 29 motor resurection
Well you can get a flexible cable such as an old speedometer cable etc... pieces of wire or such fiddle around in there and try to break as much loose as you can with the head off. Use an air hose and blow it out. Be sure to cover the cylinders so crud doesn't get in them.
Put the head back on and flush it out with water by putting a hose in the side inlet full blast along with air from the compressor. Prepare for a lot of water to blast out of the top outlet.
Dave / Lincoln Nebraska |
10-08-2017, 09:30 PM | #3 |
A Guy drained & stored his A, left the cap OFF & mice filled the block, head, & radiator tank, with cotton from an Old Couch!
Bill W.
10-09-2017, 11:16 AM | #4 |
Put the head back on and do the evaporust again for a much longer time and see what dissolves. JMO
Paul in CT |
10-09-2017, 08:09 PM | #5 |
The Evapo Rust in my 31 sport coupe created little about ( .060 granules ) that clogged up the overflow tube. The radiator started overflowing like the block was cracked. I took I took it all apart and found that the block was not cracked. It was just that the radiator overflow tube was clogged. I had the radiator boiled and rodded out and I'm putting it back together now.
10-10-2017, 12:43 PM | #6 |
The cleaning processes never remove all impacted rust. More junk will loosen up while driving. That is why I would use a Gano filter in the upper hose to catch the rust for at least a few hundred miles. Access is limited in the coolant jackets. |
10-11-2017, 09:03 AM | #7 | |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
