06-11-2017, 02:38 PM | #1 |
Is this a 'B' engine flywheel housing?
IMG_1416 Model B flywheel housing 2.jpg IMG_1417 Model B flywheel housing 3.jpg |
06-11-2017, 02:47 PM | #2 |
Re: Is this a 'B' engine flywheel housing?
Sure looks like it to me.
Rusty Nelsom |
06-11-2017, 03:02 PM | #3 |
Yes it is the B flywheel housing and it will have a VIN on it. If you replace it with an A flywheel housing you will need to find a B oil pan and remove the spot welds thtat go back from the actual oil pan part of the engine.
Rusty Nelsome was correct in his looks like. Dan Bixby Strictly A's Original Parts Supplier |
06-12-2017, 11:01 AM | #4 |
Yes, 1932 only. 33-34 did not have the flats on the sides, only a round hole for the anti-chatter rods.
06-12-2017, 02:14 PM | #5 | |
Bill Clutchchatter
06-12-2017, 02:45 PM | #6 |
John in cool overcast high pressure on the way Suffolk County England . |
06-12-2017, 11:23 PM | #7 | |
"Someone"?? wrote, "Two like countries, separated by a common language"!!!---LOL Bill Yankee
06-12-2017, 11:43 PM | #8 |
