Old 06-25-2015, 07:59 AM   #1
frederic
Default Fan questons
i am thinking of putting an 8 blade (8 bolt) 8ba fan on my 4 blade 59ab pulley. does this work #1 ? is it a pie in the sky idea, me thinking it will pull more air ?? or will it just drag the engine down ? looks like it would clear all hoses etc. I am sure someone has tried it. any suggestions.
thank you
frederic is offline   Reply With Quote
Old 06-25-2015, 08:17 AM   #2
BILL WZOREK
BILL WZOREK's Avatar
Default Re: Fan questons
What year? A lot of ideas here if it's a heating problem you are trying to solve / Most won't ROB Hp from you.
BILL WZOREK is offline   Reply With Quote
Old 06-25-2015, 06:26 PM   #3
frederic
1947 ford 59ab really no heating issues even at 111 degrees here in AZ, just nothing to do in my head so I think up these silly ideas. I have an 8 blade fan sitting around and thought it might add something (in function and looks) but it also might drag making the engine work harder.
thanks
Old 06-25-2015, 06:30 PM   #4
El Rat
I have learned the hard way...Don't fix it if it "ain't" broke!
El Rat is offline   Reply With Quote
Old 06-25-2015, 09:05 PM   #5
Ford Freak
Yep , me too !!
Ford Freak is offline   Reply With Quote
Old 06-25-2015, 10:48 PM   #6
Drbrown
Drbrown's Avatar
An eight blade might add noise and remove more fingers. My '47 has a six blade fiberglass fan and sounds like a WW2 B19 taking off. Thinking of converting to an electric or adapting a thermo clutch to it.
Drbrown is offline   Reply With Quote
Old 06-26-2015, 12:23 AM   #7
WestCoast
eight bladed fans were made for stationary engines, generators water pumps, winches, they were needed because air wasn't forced thru the rad with a moving car, leave the car alone
WestCoast is offline   Reply With Quote
Old 06-26-2015, 05:24 PM   #8
frederic
I JUST PUT IT BACK ON THE SHELF. On to the next hair brained project !!!!
thanks people
Old 06-27-2015, 11:11 AM   #9
Barn Junk
Barn Junk's Avatar
Also most stationary setups pushed the air through the rad (why blow hot air over the hot motor) so they are impractical for auto use.
Barn Junk is offline   Reply With Quote
Old 06-27-2015, 11:24 AM   #10
CA Victoria
CA Victoria's Avatar
Stock 6 blade fan common to F-1 pickup
Have seen 4 blade too using the same hub.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 06-27-2015, 11:27 AM   #11
CA Victoria
This aluminum hub offered for alternators uses the early bolt on fan blades. Will it fit a generator?
Tim
Downtown, Ca
Old 06-27-2015, 05:42 PM   #12
Chappy
Won't that put the fan too high to actually pull air through the radiator?
Chappy is offline   Reply With Quote
