Old 02-16-2014, 12:39 PM   #1
Henry Hopper
Henry Hopper's Avatar
Default Inlet manifold interchange ?
Is the later 8ba type inlet manifold a straight swap onto the earlier motors without any mods?
If any mods are required ,what is involved.?
Many thanks.
Henry Hopper is offline   Reply With Quote
Old 02-16-2014, 02:23 PM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: Inlet manifold interchange ?
Yes the intake will bolt onto the block. However the fuel pump boss is at a different height and the generator mount might need some thought. But I've used the Merc intake on the 59A block.with an electric fuel pump and a home made alt adapter.
Old 02-16-2014, 02:51 PM   #3
Henry Hopper
Thanks Ron, the car already has an electric fuel pump, so no worries there....does the manifold need any mods regards crankcase ventilation....someone mentioned that you might need to fit a PVC valve set up.... Is that right or not?
Old 02-16-2014, 03:32 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
The PCV system is very easy to set up or you can just block the front breather hole and the 8BA oil filler hole and make a stand pipe on the back with a breather oil filler cap. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 02-16-2014, 03:53 PM   #5
Henry Hopper
Thanks for the replies lads.....much appreciated.
Old 02-16-2014, 06:19 PM   #6
Ol' Ron
Ol' Ron's Avatar
What Walt said, forgot.
