01-05-2014, 11:39 AM | #1 |
1940 Coupe diff ratios
Can anyone tell me what rear end ratios the 40 Standard Coupe came with from the factory, or how it's possible to tell what I have without resorting to stripping the unit and counting teeth.
Thanks. |
01-05-2014, 12:01 PM | #2 |
Re: 1940 Coupe diff ratios
put a chalk mark on crankshaft pulley,roll car so tire valve stem is up---or down , put in 3rd(or if other type of trans whatever gear is direct), push car untill valve stem is in same position while counting revolutions of crankshaft ---3-1/2 rev is about 3:54, a little more than 4 is 4:11 ---most likely it is 3:78, about 3-3?4 turn.
Sometimes it is stamped into the web near where the torque tube attaches --but that only works if it hasn't been changed. |
01-05-2014, 12:08 PM | #3 |
Thanks Kurt.
01-05-2014, 01:09 PM | #4 |
Hi Nige. My 40 had 3.78 fwiw.
Mart. |
01-05-2014, 01:16 PM | #5 | |
60 horsepower had 4.55. Info. is from book shown. Last edited by 19Fordy; 01-05-2014 at 01:24 PM. |
01-05-2014, 01:27 PM | #6 |
01-05-2014, 01:37 PM | #7 |
You sure on that tyre size? They seem very wide to me. If you could supply an accurate engine rev figure and an accurate speed (via sat nav) I could back calculate the diff ratio.
Mart. |
01-05-2014, 02:37 PM | #8 |
Oops...275. not 375 ha ha....I'll try and get an accurate speedo reading and a tachometer reading....it's an excuse to take the coupe out..
01-05-2014, 02:43 PM | #9 |
I made an assumption that 375 70 was a typo and 275 70 was intended and I used 3900 rpm, with 29.5 in tall tire. With 4.11 gear he would be at 83.3 mph. A 4.88 gear would give 70 mph; I'm thinking maybe 4.44 ( 60 hp gear ) and the wrong speedo turtle. Just a guess
01-05-2014, 03:01 PM | #10 |
I just used this calculator
http://www.tremec.com/calculadora.php and got similar numbers to Joel. Like I said, an exact engine rev number and vehicle speed will do the trick. Mart. |
01-05-2014, 03:03 PM | #11 |
I would recheck tire diameter, engine RPM at a steady speed (mph) before I tore anything apart.
Tire dia(in.)x3.14159 x eng RPM/ rear ratio x 1056 = mph |
01-05-2014, 05:01 PM | #12 |
40's with the 60 engine had 4:44 gears
