Old 07-07-2013, 05:42 AM   #1
Henry Hopper
Henry Hopper's Avatar
Default Starter motor on 12 volts.
My 40 coupe has 12 volts and the original 6 volt starter..it works a treat, but I'm wondering if I should be aware of any potential issues.I would like to sort any problems before they arise and leave me bump starting it out on the road somewhere.Will the starter motor need upgrading or replacing, if so what's the plan?
Thank you .
Henry Hopper is offline   Reply With Quote
Old 07-07-2013, 05:49 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Starter motor on 12 volts.
Been running my 6 volt starter on 12 volts for over 15 years no issues.
There have probably been as many problems when running on 6 volts as there ever were on 12 volts.
Old 07-07-2013, 06:27 AM   #3
chuck stevens
chuck stevens's Avatar
You might want to have a starter drive spring on hand, I have broken a few with 12 volts. Easy fix, and everything else is ok.
chuck stevens is online now   Reply With Quote
Old 07-07-2013, 09:11 AM   #4
34PKUP
34PKUP's Avatar
Have never broken one in the last 10 years on 12 volts but over the past years have broken a few on 6 volts
34PKUP is offline   Reply With Quote
Old 07-07-2013, 09:25 AM   #5
Henry Hopper
Thanks fellas.....
Old 07-07-2013, 09:30 AM   #6
V8 Bob
V8 Bob's Avatar
Having the starter converted/rebuilt to 12 volts will minimize ring gear wear and Bendix spring failure, along with slowing starter rpm to sound like a V8 flathead should, IMO.
V8 Bob is offline   Reply With Quote
Old 07-07-2013, 09:45 AM   #7
Shadetree
Shadetree's Avatar
The thing I notice most on my F1 are the quick starts even after having set for awhile. The starter is used less therefore should compensate in part for the higher voltage.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 07-07-2013, 09:50 AM   #8
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Nothing like the sound of a Flattie starter....was watching an old movie on TCM last week, heard a Flattie starter off camera...next scene up drives a 40 Woodie
dean333 is offline   Reply With Quote
Old 07-07-2013, 10:55 AM   #9
Henry Hopper
I agree the sound is special..but the quick zap of the 12 volts through the starter and easy starting more than compensate....previous cars Ive had always had me wondering if it was going to fire on 6 volts.
