01-25-2011, 03:39 PM | #1 |
Location: Keweenaw Bay, MI (Michigan's Upper Peninsula)
Ny-Lock Nuts
I have the pan off of my "A" and I am going to plastigage the rods & mains. Has any of you used Ny-Lock nuts on the rods and mains? They seem to do good on other machinery that has lots of movement and vibration.
01-25-2011, 03:58 PM | #2 | |
Re: Ny-Lock Nuts
Use Marsden nuts. These are used in most modern engines. |
01-25-2011, 10:05 PM | #3 |
Re: Ny-Lock Nuts
DON'T use nylocks. The nylon can break down in oil. Doing split pins is a supperior option, I think you call them cotter pins in the US. If you are addament about using lock nuts, search out the all metal variety, they're used on aircraft. Try 'aircraft spruce and specialty' for supplies.
01-25-2011, 11:30 PM | #4 |
Re: Ny-Lock Nuts
I hear where your coming from the carter pins can be a pain to put in at times . Lock nuts of the all metal veriety work great. I used them on my 30 A with high way driving and had good luck with them.
01-26-2011, 01:41 AM | #5 |
Re: Ny-Lock Nuts
Yea but really, how often do you remove those cotter pins.
01-26-2011, 11:02 AM | #6 |
Re: Ny-Lock Nuts
01-26-2011, 06:09 PM | #7 |
Re: Ny-Lock Nuts
I bought a bag of metal lock nuts at Fastenal, but they are taller and heavier than stock and I decided not to use them. If I still have them and anyone wants a set for the cost of postage, let me know.
01-31-2011, 02:20 PM | #8 |
Re: Ny-Lock Nuts
Where can I find Marsden nuts? I havetried Fastenall and many auto parts stores and they never heard of them.
01-31-2011, 02:35 PM | #9 |
Re: Ny-Lock Nuts
Granger's??
Paul in CT |
01-31-2011, 04:38 PM | #10 |
Re: Ny-Lock Nuts
01-31-2011, 04:44 PM | #11 |
Re: Ny-Lock Nuts
I ordered them online. We don't have much choice up here in Michigan's Upper Peninsula.
01-31-2011, 05:04 PM | #12 | |
Re: Ny-Lock Nuts
02-01-2011, 08:47 AM | #13 |
another opinion.......
don't use Plastigauge.
the Mike Flanagan aluminum foil method is easier and more accurate. full description of the process is somewhere in the Ahooga.com archives, but here's the short version: cut a piece of doubled thickness heavy duty aluminum foil the same shape as the babbit in the cap. check with your micrometer to make certain it's .002 thick. put the foil in the cap & snug the bolts. if it turns with the foil in place, it's too loose, remove some shims. if it turns without the foil but won't turn with it, clearance is OK. |
02-01-2011, 09:15 AM | #14 |
Re: Ny-Lock Nuts
As allready said nylock nuts will not take the heat, plus they might be grade 3. I would want grade 8
02-02-2011, 09:11 AM | #15 |
Re: Ny-Lock Nuts
What do you mean by weak threads?
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
02-02-2011, 12:17 PM | #16 |
Re: Ny-Lock Nuts
Where the nuts are turned down for the cotter pin. There is not much to keep the nut from expanding, then stripping the thread. I will have to say the original Ford nuts were made of good material. The replacement nuts that I have seen not so good, plus the threads were a little over size.
02-02-2011, 01:08 PM | #17 |
Re: Ny-Lock Nuts
You want a Grade "C" lock nut - the all metal type (kind of 'coned' shaped on top)
Grainger, Fastenal, or Mc Master Carr, Lawson Products, all carry them Stay away from the 'nylock' nylon lock nuts - these are for 'low temp' applications Also, there are different grades of nylon lock nuts - (not many people know this) the common ones you usually find locally are only grade 5, the grade 8's will have 'notches' cut in the corners of the flats There are also 'tall' & standard height nuts in the all metal (grade C) - just be sure that you have enough threads protruding that the lock nut can fully engage the bolt |
02-03-2011, 01:21 PM | #18 |
Re: Ny-Lock Nuts
Remember that if you are using metal locking nuts, the lock nut damages the bolt threads, more with each use. Most bolts only will withstand about 2 removals/reinstalls before structure and threads are beyond usable limits.
Cotter pins do no damage. Use new ones each time. |
02-03-2011, 02:48 PM | #19 | |
Re: Ny-Lock Nuts
02-09-2011, 05:00 PM | #20 |
Re: Ny-Lock Nuts
I recieved the marsden nuts today that I plan on using on the rods and mains. What makes these a locking nut and what grade are they? I don't want to find out after there is a rod sticking through the block!
02-09-2011, 07:56 PM | #21 | |
Re: Ny-Lock Nuts
When tightened the flat distorts the body like a cone and pulls the serrations in against the thread...When not tight there is no pressure on the threads. This is why you can spin them on and off by hand and can reuse them. Most Marsden nuts are at least grade 8. Fastener quality is not a good place to skimp. Question: Ever wonder why the hot shot engine builders seldom use torque wrenches? Answer: They use the bolt stretch method which uses a dial indicator to measure the stretch of the fastener. A plain high strength nut (no locking device) will never come loose tightened this way. Checked with a torque wrench they will usually be about 10% over the NORMAL torque wrench setting. |
