02-23-2024, 05:52 AM | #1 |
33 Tudor dash light location
Where is the dash light located? I had the dash out to be wood grained and the cluster to be re-engine turned and didn’t see a bulb. Thanks.
Tim Carlig |
02-23-2024, 09:16 AM | #2 |
Re: 33 Tudor dash light location
Directly above the opening in the instrument panel for the speedometer.
02-23-2024, 09:35 AM | #3 |
Tim
Expanding on DavidG's post above All the gauges get their light from fixtures and bulbs on the back of the dash insert, there is NO external light source. As you can see on the gas gauge, the opaque strip on the back of the housing of the gauge is where the light filters into the gauges and speedometer Last edited by rockfla; 02-23-2024 at 10:04 AM. |
02-23-2024, 10:11 AM | #4 |
special bracket holds the light socket and wire, plus the dash light switch.
02-23-2024, 11:12 AM | #5 | |
02-23-2024, 11:12 AM | #6 | |
02-23-2024, 11:37 AM | #7 |
Thank you all.
Tim Carlig |
