11-07-2011, 07:15 PM | #1 |
Suggestions for slant window outside mirrors needed
Well I know this has come up before on FB, but I have a 31 slant window fordor and I need suggestions and pictures of what you guys are using for your outside driver and passenger mirrors I have a fresh paint job so I don't want anything to drill or to clip onto the doors that may damage the paint any suggestions pictures or help would be greatly appreciated thanks guys and gals.
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
11-07-2011, 07:39 PM | #2 |
Re: Suggestions for slant window outside mirrors needed
I have had LBB sideviews on my 68C hinges for a long time.
They are the ones that are "not for slant windshild cars." I do have a 3.75" convex mirror stuck on the passenger side one since it didn't have the proper view without the stick on. (I saw telephone poles and fences, but not cars along side.) |
11-07-2011, 08:38 PM | #3 | |
Thanks buddy!!
11-09-2011, 10:43 AM | #4 |
Mark, please email me your phone number. I have devised a very useful and attractive mirror setup that will not injure your finish. Clinton Perry, [email protected].
11-09-2011, 12:36 PM | #5 |
We all like to know!
11-09-2011, 06:07 PM | #6 |
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
11-19-2011, 06:09 PM | #7 |
Seems that the ONLY Solution that i have found is a peep mirror on the Wind Wings, looks good and functions well. Any one else have any suggestions at this time?
11-19-2011, 07:08 PM | #8 |
Don't give up. If I get motivated I will take some pictures of what I did to solve the very problem you are having. I did drill and tap some holes in the hinge but did not damage the paint. It's do you want to see the blind spot or just look at your nice paint job when you change lanes?
11-19-2011, 07:28 PM | #9 | |
Well lets see some pics for all of us...please
11-19-2011, 08:47 PM | #10 |
I used the black pickup mirror brackets (Bratton's # 24230, 50). I think that I had to drill the bracket holes bigger for the bigger pin and I had to find longer pins.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
11-19-2011, 09:31 PM | #11 |
I just recently mounted a side view mirror on the right side of my Victoria using the hinge pin. The previous owner had installed the same arrangement on the left side years ago. I thought the right side would be a simple task.
What I dioscovered was that the hinge pins on slant window cars are larger in diameter and the hinge pin mirrors offered by suppliers won't fit. The hinge pins on most Model A's, according to supplier documentation are .233-.236 in diameter. Oversize pins with a .244 diameter are also available to be used with bored out repaired hinges. The Victoria, Cabriolet, and slant window sedans, which have only two hinges per door instead of three, have a larger diameter pin. Supplier documentation indicates the diameter is .279 according to Snyder and Mac's, and 9\32" (.281) according to Bratton. Neither supplier offers an oversize pin. Accessory outside rear view mirrors that mount on the door hinge have a shaft pin that is sized to fit a standard Model A and cannot be used on the Victoria, Cabriolet, and slant window sedans. Neither Snyder, Mac's nor Bratton supply a hinge-mounted mirror to accommodate these cars. What I did was remove the top hinge pin on the right side. It measured a nominal 0.300. Someone must have bored it out and made a pin for it. I had a machinist friend make a new pin on a lathe the same size only longer. The bottom end was made smaller and threaded for the 1\4-20" acorn nut that comes with the mirror that is not supposed to fit a slant window car. The top hole of the mirror bracket was drilled out to fit the pin. I had to add a 0.010 shim between the hinge and the mirror bracket. Looking at the left side it appears that a larger pin was fabricated for that side as well. I now have a well suited mirror on the right side and I can see cars lurking in the blind area. Tom Endy |
11-20-2011, 01:52 PM | #12 |
I went out in the cold garage and took some pictures of the 400A and also one of the pickup mirror. When I installed them on the 400, I copied the technique used on the pickup. Along with the aforementioned pin problem, I found the mirror you buy from the suppliers won't come back far enough to be able to adjust the head so you can see. Out came the dremel tool and I just started grinding off the part that was hitting until it folded back in a suitable position for adjustment. The mounting is quite solid. Drilling the holes was not that difficult.
11-20-2011, 02:39 PM | #13 |
I have the same setup as John Stone.
The driver side mirror works great in seeing the traffic behind you BUT on the passenger side I can't bend the mirror head enough to have a clear view. What to do about it? I do have 6 inch mirrors on them now but even with 4 inch mirrors it does not work. .. |
11-20-2011, 04:34 PM | #14 |
Been there done that. Mirrors are just a blur due to vibration of the sidemounts. Also, I had leather straps and the first time they got wet, they slid back on the tire. They look nice but if you are going to drive your car, try for some good mirrors. If you see'em coming, you might be able to get out of the way.
11-20-2011, 04:37 PM | #15 | |
11-20-2011, 06:45 PM | #16 |
Joop: Mine's a tudor, hinge mount mirrors. Left side OK. "formed the rh side a bit and if I sit a "skosh" to the right it's fine. I don't have a dremel.
Paul in CT |
