Old 03-29-2019, 01:19 PM   #1
1931 flamingo
1931 flamingo's Avatar
Default heater
I need to install the hose fitting in the lower radiator hose on my 40 coupe. Any hints/instructions on how to "cut" the hose to install??
Thanks in advance for any help.
Paul in CT
Old 03-29-2019, 01:27 PM   #2
Kube
Kube's Avatar
Default Re: heater
Paul in CT
I place a block within the hose to support it. I then use a hole punch of a slightly smaller diameter than the diameter of the nipple.
DO apply Indian head Shellac to both sides of the fitting plates when doing the actual installation.
I trust you realize the nipple is NOT at the top of the hose. Rather, it is about 30° rotated to the right.
Kube is online now   Reply With Quote
Old 03-29-2019, 05:29 PM   #3
1931 flamingo
Default Re: heater
Thanks Kube AND NO I did NOT realize that !
Paul
Old 03-29-2019, 06:18 PM   #4
Kube
Kube's Avatar
Default Re: heater
Paul
Maybe kind of lay out the hose routing before you stamp out the hole in the lower hose. You'll quickly see it (the nipple) needs to be rotated from the top - center.
Old 03-29-2019, 06:46 PM   #5
Phil Gillespie
Phil Gillespie's Avatar
Default Re: heater
Did mine recently and laid it out for best clearance at vee belt.
Ended up about 35 to 40 degrees from top vertical position.
Phil NZ
Phil Gillespie is offline   Reply With Quote
