Old 12-09-2019, 08:22 AM   #1
chiefdave
chiefdave's Avatar
Default White wall care
The Cocker Classic 6.00R16 wide whites have been on my '49 since '06 and show no signs of deterioration except for the whitewalls are getting a little chalky. They only have 8K miles on them with lots of tread left and would like to keep from replacing them. Any suggestions other than Wesley's I hate that stuff.
chiefdave is offline   Reply With Quote
Old 12-09-2019, 08:53 AM   #2
RKS.PA
RKS.PA's Avatar
Default Re: White wall care
chiefdave, those Cokers are probably about 20 years old, given the manufacture date on the side wall. I've always been told that tires have a "shelf life" in addition to mileage.
Do you have any concerns about safety, the whitewall issue not withstanding?
RKS.PA is offline   Reply With Quote
Old 12-09-2019, 12:12 PM   #3
Automotive Stud
Automotive Stud's Avatar
I've had good luck with sos steel wool pads.
Automotive Stud is offline   Reply With Quote
Old 12-09-2019, 12:48 PM   #4
TJ
TJ's Avatar
If the whitewalls are getting chalky I would think the tires are starting to deteriorate. Just because you still have a lot of tread doesn't mean that the tires are still good. Most tire shops will not even fix a flat if the tire is 7 or 8 years old. There's a reason for that and it's called "liability".
Old 12-09-2019, 12:52 PM   #5
Automotive Stud
While I'm sure there's some truth to that, I would think think the life of a tire on a classic car that is garaged is probably a lot longer than on a daily that sees more weather, temperature, and uv exposure.
Old 12-09-2019, 12:56 PM   #6
TomT/Williamsburg
TomT/Williamsburg's Avatar
Some have said d Magic Eraser works well ....
TomT/Williamsburg is offline   Reply With Quote
Old 12-09-2019, 01:00 PM   #7
oldskool
oldskool's Avatar
getting back to the question diamond back recommends you use simple green on there white wall radials and not to use steel wool as they will turn the whitewalls yellow in time
oldskool is offline   Reply With Quote
Old 12-09-2019, 01:09 PM   #8
tubman
tubman's Avatar
We always used something called "Westley's Bleche White". I just looked and see it's now "Black Magic Bleche White", which it wasn't back in the day. It's probably like a lot of things, a shadow of it's former self. Might try it, though.
Old 12-09-2019, 01:23 PM   #9
TomT/Williamsburg
Old 12-09-2019, 01:42 PM   #10
FlatheadTed
FlatheadTed's Avatar
I had the rear wheel of the other day and left greasy marks on the whitewall so I got some hand cleaner you know the one with sandy texture it seemed to work good ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-09-2019, 03:21 PM   #11
51woodie
51woodie's Avatar
When I bought the new "Firestone" 6:00 - 16 tires for my '46 from Universal in Hershey, the Tech that mounted them suggested Simple Green was the best. I have used it with a stiff natural bristle scrub brush to clean the WW's, and they still look like new after two years.
51woodie is offline   Reply With Quote
Old 12-09-2019, 04:22 PM   #12
Ronnieroadster
Ronnieroadster's Avatar
I tried the Westleys bleach white years ago big mistake I discovered it destroys the whitewall after a short time. Found small surface looking cracks. So I stopped using that stuff. Now I use is Mister Clean Fabreze which im sure is similar to Simple green which i would also use if needed.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 12-09-2019, 05:19 PM   #13
aussie merc
aussie merc's Avatar
me i use white tennis shoe cleaner works a treat
aussie merc is offline   Reply With Quote
Old 12-09-2019, 07:56 PM   #14
swedishsteel
We have three sets of Diamondbacks- they instruct to use Simple Green and if a blemish/stain doesn't come off with just the soap, use some very fine sand paper. Has worked for us for close to ten years, and the whitewalls are as white as they were new.
swedishsteel is offline   Reply With Quote
Old 12-10-2019, 05:13 PM   #15
Royal Ryser
Some good suggestions above about cleaning your white walls. I have a car with white walls probably 20 years old. (Here is where people will tell me they are no good!) After I had done most of the restoration, I had a lot of grease and other dirt on them. My best solution was to sand them with 320 sandpaper, using a orbital sander I have in my woodshop, with a bit of water. If you have such a tool, it will work for you.
Royal Ryser is offline   Reply With Quote
Old 12-10-2019, 06:50 PM   #16
39portlander
39portlander's Avatar
Yes X's 2, scuff's on upholstery also.
39portlander is offline   Reply With Quote
Old 12-10-2019, 10:11 PM   #17
alandomer
I use Simple Green and a scrub brush.
alandomer is offline   Reply With Quote
Old 12-10-2019, 10:32 PM   #18
slowforty
slowforty's Avatar
Tubman is correct the new stuff does not work as well as the original stuff
slowforty is offline   Reply With Quote
Old 12-10-2019, 10:36 PM   #19
Tinker
Tinker's Avatar
Simple green works really well. think it's still available. Spray, let sit, wash off with rag and water.
Old 12-11-2019, 01:41 AM   #20
50fordcoupeman
50fordcoupeman's Avatar
I use "Super Clean". Similar to Simple Green in uses. It is about $8 a gallon concentrate. Very good degreaser too.
50fordcoupeman is offline   Reply With Quote
