07-26-2010, 11:17 PM | #1 |
Fan Blade ends close to Rad hoses ??
What is the normal distance from the fan blades ends to the rad hoses , seems like I have only 1/8 of an inch from the tips of the blades to the hoses , is there a way to fix this ? What is the normal ? Thanks Barners ..
The engine is a 21 stud , stock 34 Ford 4 dr sedan , sorry I should have posted... thanks Barners .. Last edited by Rustyspokes; 07-27-2010 at 11:26 PM. Reason: up dates .. |
07-27-2010, 06:06 AM | #2 |
Re: Fan Blade ends close to Rad hoses ??
Stock? Modified? Might help to reveal which car. In any case 1/8" is generally not enough.
07-27-2010, 08:37 AM | #3 |
Shorter belt. G.M.
www.fordcollector.com |
07-27-2010, 08:38 AM | #4 |
Please tell what vehicle, what engine and what you have already done.
A photo would be excellent. |
07-27-2010, 09:33 AM | #5 |
07-27-2010, 11:27 AM | #6 |
07-27-2010, 11:41 AM | #7 |
I cut the ends off the fan blades... Took a marker and spun the fan to make them all equal... Been running that way for a while. Karl
07-27-2010, 01:49 PM | #8 |
I did the same on a 36 6 blader i run on my pass car,no vibrations whatso ever been on it for yrs. ken ct.
07-27-2010, 11:33 PM | #9 |
Being the blade is that close probably the best thing to do is trim a bit off the blades, then I would worry about an unbalanced set of blades ?? I'll have to take another look at it tomorrow ..
