11-20-2018, 12:57 PM | #1 |
1931 right hand side tailamp with license plate lamp
Okay something I was told today but hard to comprehend.The Model A Ford never was equipped with a solid taillamp body for the right side option? I thought mine was weird because it was blocked off with something but look like cardboard to me.How did Ford block off the light or didn't they for right side? So what is correct what I have or a China Man new one that is solid?
"Never complain,never explain"... Henry Ford II |
11-20-2018, 01:19 PM | #2 | |
Re: 1931 right hand side tailamp with license plate lamp
BTW, if you are installing a right side tail lamp check the bracket. The ones made for the right side from Vintique point in the wrong direction and are longer than the original left one. In fact, if you can, veer away from Vintique junk all together... Last edited by Y-Blockhead; 11-20-2018 at 01:37 PM. |
11-20-2018, 01:32 PM | #3 |
Yes, the USA Model A had only a drivers side taillamp. There was no right side taillamp and the fender on the right rear did NOT holes in it to install a taillamp bracket. The right and left taillamp brackets are angled slightly different so they are not interchangable.
It is a safety feature to have a right bracket and taillamp on the right side. The right taillamp has no license plate lens. Think of all those right hand drive Model A's that had a right side bracket with taillamp on the right rear fender. Obviously Ford made the right side units. |
11-20-2018, 02:21 PM | #4 | |
11-20-2018, 02:21 PM | #5 |
If you have a rumble seat, the RH taillight will make it awkward to step up.
11-20-2018, 02:26 PM | #6 |
11-20-2018, 02:33 PM | #7 |
I believe that when one ordered a dealer installed second tail light, it was optional to have either with or without the clear lens on the bottom. Most likely, they were provided without the clear lens as two license plates on the rear were not generally required. Apparently the one you have is provisioned for a clear lens but was retrofitted to block out the clear lens as no second license plate was being used.
11-20-2018, 04:21 PM | #8 | |
I confess I don't know the answer so take this speculation FWIW. But AFAIK, a right side tail light wasn't an authorized Ford accessory. For that reason, I doubt they would have made a light without license lens, especially for what likely was a low demand item. As Synchro909 posted, there was a right side bracket for right drive cars but it used the light with license lens same as left drive cars. I suspect a dealer did the same if they installed a tail light on the right side of a left drive car. Presumably they could order the right side bracket. |
11-20-2018, 05:01 PM | #9 |
Many parts were available through the dealer network through the 30's but not all. Some showed up after production ended because there was a market. It is possible that parts unique to the UK and others who drove on the Left side could be available on special order while not in the catalogue. All of this is exactly what one would expect both then and now with manufacturers of any make.
11-20-2018, 06:36 PM | #10 |
Page 586 talks about the RH tail light but I have never found a part number for the bracket in the US parts books. How about our friends in Australia or New Zealand, is there a part number in the RH drive cars?
11-20-2018, 08:12 PM | #11 |
In Argentina The Model A had a right hand and the tail lamp was on driver side, that is right rear fender.
Here you have some photos |
11-20-2018, 09:33 PM | #12 |
The tail light bracket for right hand drive is AF-13471-B
Bob |
11-21-2018, 09:25 AM | #13 |
My guess, and it's just a guess, is that left and right taillights used the same teacup just with the passenger side using a block off plate instead of the lens (or it could have used the lens, again this is just a guess).
I say this because I assume that the teacup was stamped in one operation with the bottom cutout formed at the same time. This means that to omit the cutout, tooling would need to be changed to make the passenger side teacups and the downtime in doing so would probably be more expensive than simply using the same teacup for both sides even with an extra lens. However, if this isn't the case and the bottom cutout was a separate operation in production on another machine down the line I would say it's logical to assume that Ford could have pulled them before the cutout was punched (save a couple pennies) and therefor the passenger side taillight would not have the bottom lens cutout. Not knowing exactly how these parts were manufactured it's hard to say but Ford probably went the cheaper route which is usually to use the same part for multiple applications. |
11-21-2018, 10:52 AM | #14 |
This has been very interesting to me and I appreciate all the responses. I have only had the roadster since August but from day one I noticed the right side tail lamp was a license plate light left,blcked off years ago at least 55 years ago. I looked at all the pictures of the '30 roadster my dad restored while I was in the Navy 1966-1970 and only have side shots but shows he had a right side lamp on that car.I am going to keep what was placed on this car I know almost 60 years ago rather than use one of the solid ones made today in Taiwan. Ironically just a year ago I was trying to find a right side for a 1932 Plymouth convertible coupe and a very well made China Guide type was used but you can not get them with a license plate lamp for the left,you have to cutout yourself. The originals for these cars was a very thin brass chrome plated that cracked everywhere so the China ones which is the exact dimension was a lot better.
11-21-2018, 11:36 PM | #15 |
Wish I could remember where I saw it, but I recall reading somewhere, maybe here, that if the right tail light was added on US cars, there was a red lens that was used to replace the clear one.
11-22-2018, 12:08 PM | #16 | |
You probably saw it on Ford Barn and you posted on it. https://www.fordbarn.com/forum/showt...d+license+lens |
11-22-2018, 05:20 PM | #17 |
Well that is new info.
11-22-2018, 05:53 PM | #18 |
11-22-2018, 06:02 PM | #19 |
Canadian vehicles exported down under in face where different than USA ones not just mounted on the other side, The duo stamping was depressed where as USA are-raised ,correct me if im wrong , but that's what ive seen ,33-34 both lhand & rhand ones produced,
