05-04-2018, 12:40 PM | #1 |
Front spring question.
Thanks Bob, pictures below.
05-04-2018, 12:43 PM | #2 |
Re: Test post transfer
OK, cheers, Chris
05-04-2018, 12:48 PM | #3 |
On here
05-04-2018, 01:54 PM | #4 |
Not sure where your coming from or want to go but maybe just copy and paste.
05-04-2018, 02:45 PM | #5 |
05-04-2018, 03:24 PM | #6 |
Re: Front spring question.
Good springs and shocks or needed for good handling and ride. The one in the pictures is shoot. |
05-04-2018, 06:03 PM | #7 |
Springs look to be in pretty good shape to me.
John |
05-04-2018, 06:56 PM | #8 |
Guess there are 2 way; heat and bend the ears up (but you might change the temper of the steel leafs by time they are hot enough to bend) or cut and remove then replace with the style that uses thru bolt under leafs. Or just try prying them up.
I know the voices aren't real but damn they have some good ideas! |
05-04-2018, 08:52 PM | #9 |
hammaer and chisel , polish the leafs . Polish all the foot prints and polish the toe up so it does bind later.
Paint grease ,reassemble with clamp after you bolt the main back on your pearch . New bushing in all.
"I can't cry as long as I know the Lord has risen " |
05-05-2018, 07:42 AM | #10 |
They should measure 31 1/2" center of eye to center of eye.
If they are a lot more than that I would be tempted not to use them |
05-05-2018, 08:40 AM | #11 |
I have 31"
05-06-2018, 01:10 PM | #12 |
I agree with the 're-use' statements.
Especially, if is doesn't have any broken leafs and still measures 31", as you state. Heck, if that were my spring, I would have started out with a much better one than was original to my '30 roadster....and it is still on the car and doing fine after some attn. Also , if mine, and if you wanted to buy it....you'd have to pay extra for the 'patina' that has developed there over 80 years ! |
05-05-2018, 09:09 AM | #13 |
The springs have now been cleaned up, is it best to assemble them exactly the same order they came apart.
05-05-2018, 09:36 AM | #14 |
05-05-2018, 11:31 AM | #15 |
If your planning on using your car as a driver and want it to be safe handling. Spend the money and buy a new spring. $130.00 to $220.00, depending on quality.
That spring has been on a car with weight on it for 90 years. It’s rusted badly, and you know what, it could break once you start driving. There are some things that sanding and a coat of paint will not make like new. Springs are very important. It’s time has come, replace it. One less thing to worry about. Enjoy. |
05-05-2018, 06:51 PM | #16 | |
Unless I could be 100% assured that a new spring was not made in China I would take my chances with a 90 year old spring. John |
05-07-2018, 03:15 PM | #17 |
Great, after all the cleaning of the springs using a small angle grinder I've now got 'Popeye elbow'
05-07-2018, 03:21 PM | #18 |
Those clamps you have holding your leafs together are not original style. The originals were C shaped, fitted over the top of the leaf, and with the legs extending past the bottom. The legs have holes in them, and bolt goes across the bottom.
05-07-2018, 07:56 PM | #19 |
A -Spring company in Hartford CT sells new USA made main leaf and build up from there with yours .....
05-07-2018, 11:15 PM | #20 |
I'm 82 5/12ths years Old & Folks still DEPEND on me! I have 7 1/2 DEPENDENTS! Can I claim them on my TAXES?
Bill Doe
