Old 02-14-2018, 09:52 PM   #1
bucket-o-rust
Default zenith carb
I have a zenith carb that for some reason does not have threads in the secondary well hole to screw the brass secondary well fitting into. Is that a normal carb or is it some kind of mistake?
bucket-o-rust is offline   Reply With Quote
Old 02-14-2018, 10:22 PM   #2
F.M.
Default Re: zenith carb
Normal..
F.M. is offline   Reply With Quote
Old 02-14-2018, 10:31 PM   #3
Mike Peters
Mike Peters's Avatar
https://www.macsautoparts.com/ford_m...dary-well.html
Is this the secondary well pf which you are referring?
Mike Peters is offline   Reply With Quote
Old 02-14-2018, 11:05 PM   #4
bucket-o-rust
Yes that is the part
Old 02-14-2018, 11:44 PM   #5
Bill Cilker
Bill Cilker's Avatar
You have an early 1928 carb.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 02-14-2018, 11:48 PM   #6
Gary WA
Gary WA's Avatar
Double Venturi Holley Jun 27-Jun 28
www.whidbeymodelaclub.com
Old 02-15-2018, 12:43 AM   #7
bucket-o-rust
I know nothing about the past on this carb. I came by it when I purchased a basket case model A . It has a single venturi in it now. Do I need a double venturi in it before it will work?
Old 02-15-2018, 07:10 AM   #8
kenparker
kenparker's Avatar
yur carb wil wrk juz fine with no secondary well and a single venturi . I have one running on my early ccpu engine.
kenparker is offline   Reply With Quote
Old 02-15-2018, 08:18 AM   #9
Keith True
Keith True's Avatar
Look in the intake end of the carb,with the choke open.Are the two jets inline,or offset from one another?If they are inline it is a true double venturi,and if they are offset then it is a single venturi.
Old 02-15-2018, 10:35 AM   #10
1928Mik
1928Mik's Avatar
Bill C. is correct, early '28 carb, single venturi. Mine is the same and it's the original.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
