Old 08-20-2015, 04:21 PM   #21
Mitch//pa
Default Re: thermostat installation
different areas of the cooling system ..ie.. engine block will get hotter than 160 at first before hitting the thermostat in the upper hose....
then when the stat see's 160 youll get a rush of cool water from the radiator.
Old 08-20-2015, 09:46 PM   #22
denis4x4
denis4x4's Avatar
I use a pot of water on the stove and a candy thermometer to determine exactly when the thermostats opens and closes. Over the years, I've found that what's marked on the box isn't always correct. I've returned several thermostats that were not as advertised.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 08-20-2015, 11:56 PM   #23
Henry1953
Henry1953's Avatar
I used the Vintage Precision adapter and couldn't be happier. Great company, very quick shipping.
Henry1953 is offline   Reply With Quote
Old 08-21-2015, 12:02 PM   #24
Glen in Hillman MI
I run with stat at Radiator neck but drill two 1/8th holes for exter bypass coolant. It stops the hunting for temp.
Glen in Hillman MI is offline   Reply With Quote
Old 08-21-2015, 01:35 PM   #25
Richard Lorenz
I removed my thermostat from the car and made a test which proves that everyone is correct. At 166 deg. the thermostat had moved (opened) 1/8 inch; at 173 deg it had moved 1/4 inch; at 179 deg had moved 3/8 inch, and at 186 deg it had moved 1/2 inch which was the maximum movement.
The first 1/8 inch is probably enough for cars whose engine is broken in. For my new engine I was making use of the full thermostat movement. With vigorous boiling of the pot in which the thermostat was located, the temperature reading was 213 deg. Barometric pressure was 30.1 inches, so that adds to the validity of my temperature measurements. I was using a multimeter that used a thermocouple to measure the temperature.
Richard Lorenz is offline   Reply With Quote
Old 08-21-2015, 06:11 PM   #26
steve s
steve s's Avatar
Richard,
Two questions:
Did you pause the heating process a bit at each of the test temperatures, to be sure that the stat had time to equilibrate?
That's a 160-degree stat, right?
Thanks for providing data!
Steve
steve s is offline   Reply With Quote
Old 08-22-2015, 08:41 AM   #27
Richard Lorenz
Mine is a 600 deg thermostat. On the outside is printed "52mm" and "USA". The inside has "600" and underneath it "2200" on the copper bulb. I am confident that my heat-up rate was slow enough that the readings are good. The temperatures that I quoted could be off by a degree or two.
Old 08-22-2015, 10:32 AM   #28
mshmodela
mshmodela's Avatar
Good advice! I did the same, she worked as mark 160F...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-22-2015, 11:28 AM   #29
CarlG
CarlG's Avatar
600 degrees?????????
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-22-2015, 12:34 PM   #30
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
600 degrees would cook PIZZA!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-22-2015, 01:48 PM   #31
Y-Blockhead
Y-Blockhead's Avatar
Bill W.
Me thinks it would cook the engine too!!!
Old 08-22-2015, 09:03 PM   #32
Brian in Wheeling
Brian in Wheeling's Avatar
Don't over-think it. Put it in the upper hose with a sleeve. I run a 160... All good.
Brian w.
Brian in Wheeling is offline   Reply With Quote
