01-19-2012, 11:36 AM | #1 |
ID Ring and Pinion Part number please?
I bought a Lincoln transmission from a guy and he said, "Here, take this box also" which had a ton of rear end bearings and races in it. Also in the box was a ring and pinion. It has a tag that the writing is illegible on it saying what it came from. Looks like it says something like 3.54 out of (53?) Merc.
The pinion is 10 spline, 11 tooth part # 1A-4610-B The ring is 39 tooth part # 1A-4210-B Thank you for your help!
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
01-19-2012, 12:15 PM | #2 |
Re: ID Ring and Pinion Part number please?
1A prefix is 51 Ford
01-19-2012, 12:37 PM | #3 |
1A is '51 Ford. Look for etched serial numbers. The same serial number should be etched on both the ring and the pinion. Don't go with a mismatched set.
Alan |
