04-20-2014, 05:44 AM | #1 |
another zenith carb question
Had a regular Zenith carb on my late 1931 pu. Purchased a carb kit with the correct sized jets. Rebuilt carb then worked properly gav open 1/4 turn when warm.
Recently bought a used side bowl carb. Disassembled and cleaned the passages with the paper clip method. Reassembled and installed the carb. To my surprise it idles properly even after a hard test stop, doesn't leak. I open the gav valve one turn when cold. After the car warms up with the gav open 1/4 turn the truck doesn't pull like it should. I have to open the gav valve one turn then all is well. What should I check next? Should I switch the main jet from the other carb? Thanks in advance. Charley |
04-20-2014, 05:52 AM | #2 |
Re: another zenith carb question
yes, good idea to swap jets and see... sounds like main or compensator jet too small, or maybe partial blockage in those circuits.
04-20-2014, 05:55 AM | #3 |
another idea along with the jets is to check for any play in the throttle shaft causing it to suck air and run the carb lean. very common ..
04-20-2014, 11:25 AM | #4 |
