09-27-2013, 12:22 AM | #1 |
5 sp. trans
What S10 tranny 5sp. would be the best match for my 53 EAB. Either I ad overdrive or this S10 thing. What do you fellas think?
09-27-2013, 03:16 AM | #2 |
Re: 5 sp. trans
You will probably get shot down for mentioning t5 Ch**v on here . But it is a great addition to make a comfortable long legged cruiser. Any T5 out of an S10 pickup will work as it has the ideal shifter position. An early one is preferred due to being mechanical speedo. Can't remember the specifics on which has what ration in 5th but a number search wil pull that up. One has .86 and the other .73 I think. But there is quite a few modifications to wishbones and driveshafts to consider also.
09-27-2013, 05:17 AM | #3 |
Re: 5 sp. trans
For what it's worth....I added the T5 to my '35 slantback with a hot 8BA.....loved it!
09-27-2013, 08:01 AM | #4 |
Re: 5 sp. trans
The s10 5 speeds are great. check out the H. A. M. B. sight. there is lots of info there. there are many different gear sets in these transmissions. avoid the ones with the 4.03:1 1st gear.
09-27-2013, 08:17 AM | #5 |
Re: 5 sp. trans
Been selling the T-5 S10 tranny conversion for over 15 years. Most complete on the market. If you are planning on using your stock speedo I like the 85/89 trans as it has a manual speedo cable hookup. Most installations use the stock clutch linkage. Gary at Cornhusker Rod and Custom
09-27-2013, 09:35 AM | #6 |
Re: 5 sp. trans
09-27-2013, 09:54 AM | #7 |
Re: 5 sp. trans
yes the t-170 (f150 o.d. trans) is a bolt in kit.
09-27-2013, 10:21 AM | #8 |
Re: 5 sp. trans
What year F150?
09-27-2013, 11:00 AM | #9 |
Re: 5 sp. trans
Three variations of the T170F were used in F100/150s from '78-85. It's a 3-speed with OD. All the gears are in the same case like a 4-speed toploader, though, unlike some units that'd have an OD unit added on in place of the tailshaft housing.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
09-27-2013, 01:21 PM | #10 | |
Re: 5 sp. trans
Remember --- the farther away the shifter, the longer the shifter "stick" has to be. The longer the stick, the longer the throws between gears. If that's not a concern, an S10 T5 can be made to work. Look for a T5 from an Astro Van (which is what I'm using). That shifter is closer to the seat. Beware, however, that many S10 T5s have a REALLY low first gear... like 4.03. Factor that in when you go shopping. Keep in mind that you can install just about any gear set in just about any T5. Yes, there are exceptions. If at all possible, have a competent shop go through whatever T5 you buy and replace any worn or broken parts BEFORE you install it. Believe me, UNinstalling and then REinstalling is not a lot of fun. Last edited by Richard in Florida; 09-27-2013 at 06:26 PM. |
09-27-2013, 01:58 PM | #11 |
Re: 5 sp. trans
I am using the T5 from an S10 pickup. It is a non World Class which has a mechanical drive for the speedo. I don't like the stump puller first gear ratio ( 3:54 rear end ) and end up driving around town in third gear to keep the RPM's at around 2000. I had a transmission shop take it apart to check for problems. They said it was OK. It does have very bad whine in 3.4 and 5th gears. The shop said they didn't check the bearings because they have to be broken open to see if they are OK. Now I have to remove ( hate it when that happens ) and have them replace the bearings. If it is not too expensive I will have the low gear ratio improved.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
09-27-2013, 03:44 PM | #12 |
Re: 5 sp. trans
Beware also that later ('93 for sure) S-10 T5's are WC but have a Ford bolt pattern on the front, as well as the electronic speedo. These use a more expensive adapter (not the Speedway one). Most of them have the 4.03 1st gear, too, compared to (usually) a 2.78 in the 3-sp. Great for stumps and parades, tho!
'52 F-1, EAB flathead |
09-27-2013, 04:42 PM | #13 |
Re: 5 sp. trans
Most all of the T5s have a tag on the driver side off one of the lower tailshaft bolts - that has a number starting with 1352-xxxx followed by 3-4 numbers. Google this number and you will get the gear ratios within.
That being said, in general the 4-cyl cars had the stump puller 1st gear I think and the V6s tend to have more power and use the lesser one. Mechanical speedos came in the 83-87 versions, with somewhere in 88 they moved to electronic. 88-92 have the electronic speedo and usually have a nice gearset. Krylon32 has the kits for these and even the later styled (beyond 92) T5s - Gary is a great guy and many have used his kit. I have a T5 in my avatar and in my 40 coupe - gas mileage doesn't change all that much (at least for me) but RPMs go way down - my avatar @ 75 = 2500 RPM (has a .8 5th gear) where my 40 coupe is @ 2200 when at 75 (.72 5th gear). Of course rear gears, rear tire size, and your 5th gear ratio have to be taken into consideration when calculating your final speed/rpm range. |
09-27-2013, 08:06 PM | #14 |
Re: 5 sp. trans
I have a '82 T5 in my '48 F1. It has the 4.03 1st gear, but I use it as a truck and haul heavy loads so I like the "granny" 1st gear. Used the Cornhuskers kit and it was a painless installation. Every little piece needed was there and everything fit perfectly.
09-27-2013, 09:20 PM | #15 | |
Re: 5 sp. trans
09-27-2013, 09:53 PM | #16 |
Re: 5 sp. trans
Put one in my 38. Runs down highway really nice. Makes it an enjoyable trip when you can run down the highway with the traffic.
"If you always do what you have always done then you will always get what you always got." Henry Ford |
09-27-2013, 10:29 PM | #17 |
Re: 5 sp. trans
Richard in Florida mentioned the long shifter throw between gears on some installations.
That can be remedied with a short throw shift adaptor. The gear set you choose depends greatly on how you drive and how much hp your engine has. A slightly modified flathead really works well with the closest ratio gear set the T5 came with. The 1352-202. Even this can be improved on if you have a transmission shop build the transmission. They change the .8 OD to the .86. There are lots of other internal mods that a shop can do for nominal extra cost but aren't needed for the average cruiser. With a 4.10 rear end, I cruise at 2000 rpm at 70 mph and the 2.95 first gear will launch the car with more than adequate tire smoke. |
09-28-2013, 07:40 AM | #18 |
Re: 5 sp. trans
09-28-2013, 01:45 PM | #19 |
Re: 5 sp. trans
09-28-2013, 03:08 PM | #20 |
Re: 5 sp. trans
09-28-2013, 03:50 PM | #21 |
Re: 5 sp. trans
09-28-2013, 05:00 PM | #22 |
Re: 5 sp. trans
The challenge with the T5 is there are so many variations that everyone in this thread is right, and everyone is wrong to some extent. There are very, very few absolutes.
For most early Fords, the S10 has the most favorable shifter position. For '49 up cars, the rare Astrovan is a little more favorable and the Mustang/Camaro tailshifters can be made to work. There is no "this engine had this ratio" rule that works for all years. You HAVE to decode the tag to determine the ratios - there simply is no other way. Click on the link in my signature - it takes you to the HAMB articles - read through that. Personally, the T170 and all the other 3+OD conversions are not my cup of tea simply because you still have all the drawbacks of the 3-spd transmission (wide gear ratios) and very little benefit. But it's courses for horses - some folks like them.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
09-28-2013, 06:08 PM | #23 | |
Re: 5 sp. trans
09-28-2013, 08:11 PM | #24 |
Re: 5 sp. trans
09-28-2013, 09:21 PM | #25 |
Re: 5 sp. trans
The average SEMI MODIFIED flathead can destroy a T5 in one shift if you know how to do it!
No need to elaborate on that. If you want to drag race, get a Lenco. Flat Ernie sed, "Personally, the T170 and all the other 3+OD conversions are not my cup of tea simply because you still have all the drawbacks of the 3-spd transmission (wide gear ratios) and very little benefit. But it's courses for horses - some folks like them." He is dead nutz on. "SOME FOLKS LIKE THEM". Anybody into good driving performance, wouldn't give them a second glance. |
09-28-2013, 11:09 PM | #26 |
Re: 5 sp. trans
09-29-2013, 12:25 AM | #27 |
Re: 5 sp. trans
"I meant, and I thought you meant, destroy a T5 with sheer power and torque"
Sure you will have to abuse it to break it....Very few mechanical things break if the DUL (design ultimate load) is never exceeded. Remember the best T5 models are only rated at 310 ft.lb. No abuse and they will last a long time. For years they used a model A transmission behind the 270 Offy's at Indy. |
09-29-2013, 11:40 AM | #28 | |
Re: 5 sp. trans
Every transmission is a compromise. Go search for some of my older posts where I give details on RPM drop between shifts between a 3-spd and a 5-spd. But this goes to how you drive your flathead. As for the strength of a T5, you can build them plenty strong. The early S10 T5 is among the weakest of the lot, but will still handle your average flathead with ease. If you want to abuse it, you can break just about anything. But the T5, even the early NWC with a 4.03 gearset (the weakest), is more than adequate for a flathead. There are many things you can do to reinforce some of the inherent design weaknesses of the T5. And the Mustang 5.0 crowd run them behind 10-second cars. Like I said: Courses for horses. WHY are you changing from your early Ford 3-spd is the real question and will tell you which transmission to choose...
09-29-2013, 02:22 PM | #29 |
Re: 5 sp. trans
The internet is a strange thing. I never meant that a T5 is weak, I was saying that a 3+1 is unbreakable COMPARED TO AN EARLY TRANS.
09-29-2013, 02:56 PM | #30 |
Re: 5 sp. trans
If the throw of the shifter on any s-10 is too long check out the Langdon Stove bolt Chevrolet website ( yeah I know) for a downloadable PDF on how to shorten it. Easy and inexpensive.
09-30-2013, 03:52 PM | #31 |
Re: 5 sp. trans
When I built my 34 coupe I paid the price and went for a new T5 WC from Summit for about $1250.00. You can spend that kind of money on having a S10 T5 rebuilt. I installed a tail housing out of a S10 to move the shifter forward. Works great with 411 gears and the blown 296" flat motor..
09-30-2013, 05:01 PM | #32 | |
Re: 5 sp. trans
It's all good - if we all liked the same things, it'd be a pretty boring place.
09-30-2013, 05:18 PM | #33 |
Re: 5 sp. trans
Don, I checked out Langdon's site but could not find the info on the T-5 shifter. where would I find it? thanks!
09-30-2013, 07:50 PM | #34 |
Re: 5 sp. trans
I love this country; it's the damn idiots running the government I'm afraid of. |
09-30-2013, 09:24 PM | #35 |
Re: 5 sp. trans
That's a great idea! I'm doing that to my shifter!
