05-13-2016, 02:41 PM | #1 |
Radiator Mount 47 Pickup
Is there a wooden block or some sort of rubber pad that goes between the bottom of the radiator frame and front crossmember? Been years since truck was disassembled and I don't remember how it was mounted.
05-13-2016, 02:46 PM | #2 |
Re: Radiator Mount 47 Pickup
There is a rectangle rubber pad for the bolts and springs to set on and go through.
05-13-2016, 03:36 PM | #3 |
Like .26 says the rubber pad goes between the bracket on the rad. And the frame there is a long bolt and a spring which goes on top. Sunshine.,
05-13-2016, 06:45 PM | #4 |
