Old 06-02-2015, 01:58 PM   #1
waynes
Default E-brake cable connection
Converting my 38 to 39 brakes and stumped on how to fasten tail end of front hand brake cable. Is there a bracket that connects to the wishbone braket on the torque tube?
waynes is offline   Reply With Quote
Old 06-02-2015, 02:07 PM   #2
30-9
Default Re: E-brake cable connection
Yes kinda looks like a boomarang
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 06-02-2015, 02:32 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
I know this is a crummy picture, but does it help you visualize what might work? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-02-2015, 02:44 PM   #4
30-9
Is there a trick or tool - that once u pull pin and tighten turn buckle (to tighten hand brake) to get the two cables and pin back together?
Thanks - 30-9
1939, 1940
Old 06-02-2015, 02:59 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
With the e-brake handle in the RELEASED position, there should be virtually no tension pulling on the rear cable......otherwise, you'd be engaging the brake shoes. DD
T5 W/TORQUE TUBE
Old 06-02-2015, 03:00 PM   #6
30-9
My handle is very close to bottom of dash but there is very little slack in cables even when disengaged
Thanks - 30-9
1939, 1940
Old 06-02-2015, 03:35 PM   #7
ford38v8
ford38v8's Avatar
The handle is adjustable also.
Alan
Old 06-02-2015, 03:38 PM   #8
waynes
Coopman, your pic makes it pretty clear what I need. Is that a 39 torque tube? Thanks for the response.
Old 06-02-2015, 03:39 PM   #9
30-9
Yes I know but again cable seems pretty tight already.
Also my apology steeling this thread
Thanks - 30-9
1939, 1940
Old 06-02-2015, 03:59 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
I know that picture to be of a '47 Ford car. DD
T5 W/TORQUE TUBE
Old 06-02-2015, 06:09 PM   #11
swoopNZ
MEMBER EMERITUS
The handbrake cable passes first through 2 holes in the centre bracket and then on to that clip.
The 38 chassis did not have those holes in the bracket.
swoopNZ is offline   Reply With Quote
Old 06-02-2015, 06:39 PM   #12
40cpe
40cpe's Avatar
My '38 was converted when I got it. The hand brake lever/cable still activates the cross shaft (for lack of a better word) that is on the center crossmember and actuated the mechanical brakes. The boomerang-shaped equalizer is attached to the passenger side of that cross-shaft by a rod. Maybe not kosher, but it is very effective. If a picture would help, I'll try to get one.
