11-27-2013, 10:26 PM | #1 |
Block checking
My 81a has .40 pistons with very slight ridge at top of cylinder wall. I am not interested in boring this block, but want to make sure there are no cracks, then just use ridge reamer and cylinder hone. I prefer to use as many of the parts I pulled out as possible, crank, cam, pistons, rods. I plan on replacing most/all of the valve assembly. Is sonic testing really recommended in my case? The reading I've done suggests it is used more to determine how much spare metal you have in your cylinder walls prior to boring. Any suggestions for me appreciated.
11-28-2013, 08:24 AM | #2 |
Re: Block checking
You might want to do a pressure check. I would not bother with a sonic test. Check your piston clearance. That will determine if you need the next size over bore. Your plan sounds fine to me. Rings, bearings(if needed), and a valve job, your basic rebuild. That will give you a fresh engine at a minimal expense.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
11-28-2013, 08:36 AM | #3 |
Re: Block checking
YUP! Also going to the 49/53 style guids and valves is another plus. Make sure to check valve length, I think the 49.early 51 are the same length.
11-28-2013, 04:30 PM | #4 |
Re: Block checking
Magnafluxing is also an option, it is a reliable and relatively inexpensive way to determine the quality of your block.
11-29-2013, 05:45 PM | #5 |
Re: Block checking
Yes, I was planning on magnafluxing the block minimally. Is there any issues with throwing the stock CAM back in with new lifters? I like the idea of using the newer guides. What's the best way to get the specs on guides and valves to use? Thanks for the tips guys!
11-29-2013, 07:41 PM | #6 |
Re: Block checking
A reground cam is not a huge expense... If things were to go other than the way you want, it's gotta be frustrating to go back into an engine to salvage expensive parts cause you decided to economize on a $100 part. I suggest a moderate performance cam grind... Magnaflux and pressure check do different things.. Not all cracks leak... Pressure check will find water leaks that you will not find with magnaflux... Both should be done on a new acquisition before investing lots of money. On the other hand, if you've been running an engine for a while, having no overheat or water issues, magnaflux will probably do. Karl Last edited by Karl Wolf; 11-29-2013 at 07:49 PM. |
12-02-2013, 12:17 AM | #7 |
Re: Block checking
Thanks Karl sounds like good advice.
