Old 10-11-2019, 02:21 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Helmet - condensor (vertex)
I have done this before but had to do another one today, this is a discussion and lesson on how to , not for sales etc. I dont like doing them and dont have the extra time , so if ya want one i can sell you a new Vertex unit ( .36 MFDs with lifetime warranty) perfect for the helment coils etc....and you can do it yourself.
I cut apart a old vintage condensor for the early round top three hole coil. Note the terrible connection at end of condensor and side slide strip ( ball of tin foil in end for connection) This one was still damp inside and may have worked very well ????
Use a little flux to solder the ground connection between vertex and old case ... I use a 8/32 allen to allow me to use a wire connection inside the coil housing , just ike stock. Roll wire into coil and its a stock looking condensor.....
Never seen a defective Vertex Mag Tech condensor.......???
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-11-2019, 03:52 PM   #2
Ggmac
Default Re: Helmet - condensor (vertex)
I've not mentioned this to you before, I admire your passion , skill , knowledge and the time you spend sharing it .
Thank you !
Old 10-11-2019, 04:20 PM   #3
adileo
adileo's Avatar
Thank you !
Well said - ditto
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 10-11-2019, 06:58 PM   #4
BUBBAS IGNITION
Thanks guys , i see the condensor problems every day and just wish to help, there is a fix for most of these problem....
[email protected]
