07-28-2019, 01:00 PM | #1 |
ford overdrive
is anyone making a kit to install the F150 overdrive transmission in a Model A I would like to install one in the 68B that I`m putting together.
07-28-2019, 02:15 PM | #2 |
Re: ford overdrive
07-29-2019, 07:31 AM | #3 |
Re: ford overdrive
If you want a T-5 and don't mind an open driveshaft....
John Baker Transmission Exchange Monticello, KY [email protected] 606-348-8533 I have installed one of his systems in my touring car and am well satisfied with it. Good Day! Last edited by Dave in MN; 07-30-2019 at 07:29 AM. |
07-29-2019, 10:53 AM | #4 |
Re: ford overdrive
I would go for the Chevy T-5 because of the gear ratios. The F-150 has a nice split between 1st and 2nd, and 3rd and 4th but the 2-3 shift is huge.
07-29-2019, 01:18 PM | #5 |
Re: ford overdrive
The 2-3 shift is essentially the same as a Model A transmission, isn't it?
07-29-2019, 07:05 PM | #6 |
Re: ford overdrive
07-29-2019, 07:23 PM | #7 |
Re: ford overdrive
You will not be disappointed. My Ranger 4 sped works great. Copy on the closed drive line.
07-30-2019, 06:39 AM | #8 |
Re: ford overdrive
07-29-2019, 10:20 PM | #9 |
Re: ford overdrive
Modification of the cross member is necessary for this swap.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
07-29-2019, 10:42 PM | #10 |
Re: ford overdrive
Not necessarily so.
07-29-2019, 11:47 PM | #11 |
Re: ford overdrive
Using Dave’s kit there’s no cutting or drilling except the wood floor board. It’s a complete bolt on kit.
07-29-2019, 11:03 PM | #12 |
Re: ford overdrive
Tim Sheridan, Nunica Michigan. Do a search on him.
C1-C2 |
07-30-2019, 01:54 AM | #13 |
Re: ford overdrive
x2 with Carl.
Daves kit is a first-class fit and goes in easy. For those of you that want to stay with the original look with no cutting, this is the kit. Because the gear shift is moved about 1-1/2 inches towards the rear, the floor board hole must be moved. If you have carpets them you need a new carpet. The only thing I wish this kit had is a 5th gear. |
07-30-2019, 10:59 AM | #14 |
Re: ford overdrive
CarlG, yes that split is about the same as Model A. Steve Serr of Miller hi-speed makes a closed drive line adapter for the T-5.
