10-04-2018, 08:21 PM | #1 |
popping back fire
I have a 1951 8ba with two 94 carbs
starts and idles fine on accell it pops thru the carbs any suggestions timing is set new internal balas 12 volt coil wires and plugs are new any suggestions |
10-04-2018, 08:56 PM | #2 |
Re: popping back fire
What distributor do you have?
10-05-2018, 09:04 AM | #3 |
stock steel housing distributor
10-05-2018, 09:21 AM | #4 |
Anyway to swap the manifold to stock with a single carb? Do this and If it still pops out the carb check the valve train.
10-05-2018, 09:25 AM | #5 |
10-05-2018, 10:59 AM | #6 |
10-05-2018, 11:27 AM | #7 |
Generally backfiring out the exhaust means too much advance and backfiring thru the carbs means too much timing retard. I'd look at the distributor and the timing.
10-05-2018, 11:30 AM | #8 |
Guys, He has two threads going on the same subject. On the other one he says he has a stock distributor. 'nuff said.
