Old 08-26-2019, 01:59 PM   #1
JimNNN
Default Unibody car on jack stands.
Haven't had had an old car with unibody construction til the '65 T Bird I bought last year. I need to get underneath to access the trans vacuum mo. valve. I presume the jack stands will go on the big seam weld running the wheel base along the outer edge of the underside, but I thought I'd check with you guys first.
Thanks.
JimNNN is offline   Reply With Quote
Old 08-26-2019, 06:24 PM   #2
56sedandelivery
56sedandelivery's Avatar
Default Re: Unibody car on jack stands.
On my 08 mustang you use the jack stands on the pinch weld along the outer edge.
56sedandelivery is offline   Reply With Quote
Old 08-27-2019, 01:40 AM   #3
fiddy6
if in doubt, jack up the rear axle and front suspension. If I'm going to have my 56 up for long that's what I do... closest to how it sits on it wheels.
fiddy6 is offline   Reply With Quote
Old 08-27-2019, 03:49 AM   #4
JeffB2
JeffB2's Avatar
Thanks.
This group should have the right answer http://vintagethunderbirdclub.net/ph...ic.php?t=13310
JeffB2 is offline   Reply With Quote
Old 08-27-2019, 05:29 AM   #5
KULTULZ
KULTULZ's Avatar
Post Re: Unibody car on jack stands.
... unibody construction til the '65 T Bird. I need to get underneath to access the trans vacuum mo. valve. I presume the jack stands will go on the big seam weld running the wheel base along the outer edge of the underside...
The only way (IMO) to floor jack a uni-body, especially a heavy one, is to either raise the car-
Front - placing the jack under the engine cross-member, or @ control arm mount(s) and raise and place jack-stands. You will notice short rails after the engine cradle. This is where you want the stands.
Rear- either by raising by the center section of the rear and placing the stands under the axle tubes or @ the front spring perch mounts/short frame rail extensions.
Even though there is a special jack pad to raise a car by the outer rocker panel seam, I would advise against it. Doesn't take much here to damage it.
There are also pads available for the stands that will cushion the load of the metal (sheet) to the stand.
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 08-27-2019, 05:52 PM   #6
alt63bird
And to add to this, GET THE SHOP MANUAL - it shows where the mounting points are on the underbody.
Alan H. Tast AIA, LEED AP BD+C
Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI)
http://www.vintagethunderbirdclub.net
Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years"
35+ year member, Crown Victoria Ass'n.
alt63bird is offline   Reply With Quote
Old 08-28-2019, 07:53 AM   #7
Ford blue blood
Ford blue blood's Avatar
Always get the shop manual for the car from Helm Inc., best money you will ever spend on your car!
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 08-28-2019, 11:14 AM   #8
JimNNN
Thanks guys. I do have the shop manual, but can't find anything in it about leaving the car on jack stands. Don't know how long I'll have it on stands, but I'm guessing less than a day.
