Old 05-17-2010, 12:34 PM   #1
fordfixer
Default Proto type engine or what?
Just came back from the engine rebuilder, and saw something I have never seen or heard talk about. A engine with no external oil return pipe. The oil return pipe is internal and part of the casting. It also had the crossbar connecting rods. Anybody got any info on these engines and how many might have been made. Jon
fordfixer is offline   Reply With Quote
Old 05-17-2010, 01:04 PM   #2
Rowdy
Default Re: Proto type engine or what?
This was done for a short time during 1929. Then the oil pipe was used again after that. I do not have the exact time frame, but beleive it is mentioned in the JS. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-17-2010, 03:19 PM   #3
fordfixer
That could be the case, only the builder says it was a 27 engine, it has a five bearing cam. Wonder why they didn't continue this. Hope to find out more about this type engine.
Old 05-17-2010, 03:35 PM   #4
kelley's restoration
kelley's restoration's Avatar
John at john's antique ford had one of these at the spring milwaukee show
it kind of has a side plate like a b motor
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 05-17-2010, 07:40 PM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
the non oil pipe engines were built from May thru October, 1928. It was not the entire production, so they are unusual. I know a guy with one who has been looking for the correct valve cover for several years. If anyone has one, he'd be really happy, I'm sure.
pat in Santa Cruz is offline   Reply With Quote
Old 05-17-2010, 09:29 PM   #6
Steve Plucker
This is from my "Engine Guide" on my website:
"ACCORDING TO FORD’S RECORDS OF DAILY PRODUCED ENGINES, THAT WERE ASSEMBLED BETWEEN JULY 9, 1928, (#236,787), AND OCTOBER 2, 1928, (#477,642), A NUMBER OF “SPECIAL EXPERIMENTAL” ENGINES WERE PRODUCED. THE RETURN OIL PIPE ASSEMBLY, A-6645, ALONG WITH THE OIL RETURN PIPE CONECTIONS ON THE BLOCK, A-6015, AND VALVE COVER CHAMBER, A-6520, WERE ALL DELETED. THE ADDITION OF OIL RETURN HOLES WERE DRILLED ON THE FLOOR OF THE VALVE CHAMBER TO ALLOW THE OIL TO DRAIN BACK INTO THE OIL PAN. EACH ENGINE HAD THE REGULAR MODEL A ENGINE NUMBER STAMPING TO INDICATE 1928 PRODUCTION. BETWEEN 1353 AND 1355 ENGINES OF THIS TYPE WERE BUILT. THESE CAN BE SUBSTANUATED BY THE “RELEASE” DATA OF APRIL 23, 1928 FOR EACH SPECIFIC PART AND THOSE FEW WHICH HAVE BEEN DOCUMENTED TODAY. ONE ENGINE NUMBER WHICH HAS BEEN DOCUMENTED SO FAR IS #286,625 (JULY 29, 1928). I AM SURE THERE ARE LOTS OF OTHERS".
Old 05-18-2010, 07:36 AM   #7
fordfixer
Now, I wonder if anyone is still running one of these engines? And if there is any reason why it was not continued. Thanks Pluck. Jon
