09-10-2015, 10:14 PM | #1 |
Recommended? Gorilla snot or another glue for trunk seals...
Ford barners,
I'm replacing my air vent rubber seal and my trunk seal on my '39, both of which need to be glued in. I bought a tube of 3M Auto Yellow Super Weatherstrip and Gasket Adhesive (#08001) which should be the old style "gorilla snot" glue. Is this the stuff to use or have others used other glues to better effect? I'm not certain what was originally used by Ford - anyone have an idea? Is there a black version of this adhesive? (I'm told it's nearly impossible to avoid visible gorilla snot residue when installing seals, especially the big ones. It would be nice not to end up with visible yellow spots.) Thanks, Dan |
09-10-2015, 10:58 PM | #2 |
Re: Recommended? Gorilla snot or another glue for trunk seals...
Pliobond,worked for me!
09-11-2015, 12:05 AM | #3 |
Here's the 3M black that I use. Works great. Same as the yellow stuff (#08001) only black (#08008).
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
09-11-2015, 12:23 AM | #4 |
09-11-2015, 01:17 AM | #5 |
Use it VERY sparingly, in spots rather than a solid line.
Alan |
09-11-2015, 03:05 AM | #6 |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
09-11-2015, 07:30 AM | #7 |
black 3M
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
09-11-2015, 08:05 AM | #8 |
Remember to read and follow the instructions----most people don't and just squeeze it on out of the tube---use a glue brush, spread it on both surfaces to be attached
I used to just squeeze and put it together---then I tried it by the instructions and found it works so much better that way |
09-11-2015, 10:58 AM | #9 | |
09-11-2015, 11:05 AM | #10 |
Great advice...thanks all! I'll pick up a tube of the black snot...
09-11-2015, 11:08 AM | #11 |
My friends and I cal it "black death" because if you get it on your hands it wil be there 'til the day you die.
The more I learn about new automobiles, the more I value my old ones. |
09-11-2015, 12:19 PM | #12 |
When you go to buy the black 3M adhesive also ask for the pint can of adhesive remover that 3M makes. It will remove adhesive from paint safely and also from your fingers but I don't know about safely.
"Never complain,never explain"... Henry Ford II |
09-12-2015, 07:34 AM | #13 |
Super glue works well also
09-12-2015, 11:20 AM | #14 |
Yes there is a black version. I never use the yellow as they say it will get where it isn't suppose to. Also if it does get where it isn't suppose to, either one black or yellow, give it time to dry before trying to remove it. It will soften paint or at least some some paints. Du Pont 3812 enamel reducer will take it off W/O hurting the paint that is if the paint is cured but try it in a place that isn't easily seen first. I have never had a problem with cured paint but as they say, S**T happens.
09-12-2015, 12:37 PM | #15 |
Big seals, such as the trunk, req
09-12-2015, 12:42 PM | #16 |
Big seals, such as the trunk, require at least two set of hands to position it properly, as the trim cement (we use 3M too) works so well repositioning the seal is very difficult. The best way to avoid getting the adhesive outside the intended are is to apply masking or painter's tape next to the work area.
