Old 11-19-2018, 10:09 PM   #21
reman
Default Re: New to 312 Y Block
Originally Posted by CrazyTed View Post
FMX didn't come out until 1966....
I know. I was basing this on the theory that the trans may have been the original to the motor in the Tbird. In 56 it would had to have been a Ford O. I did not notice that you had positively ID'd as a FMX
reman is offline   Reply With Quote
Old 11-19-2018, 10:37 PM   #22
CrazyTed
Okie doke.
CrazyTed is offline   Reply With Quote
Old 11-20-2018, 03:56 AM   #23
KULTULZ
KULTULZ's Avatar
Post Re: New to 312 Y Block
If an FMX, there is no TV rod. It should have a modulator valve unless someone put a manual shift valve body in it. All you will need is a downshift cable, again if not upgraded with a manual valve body.
It was introduced in the 1968 model year. Is the shift pattern 1-2-3 Select Shift?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 11-20-2018, 11:54 AM   #24
Kahuna
Kahuna's Avatar
I am 99% sure you have a 1956 Ford Ford-o-matic (early) trans. Early was air cooled, late 56 was liquid.
That ugly throttle BRACKET you are referring to, is for a 1956 car with a Teapot 4 bbl.
That bracket has been modified in the front area to accept a CABLE of some sort for throttle activation.
The existing ROD going to the carb is to insure that the kick-down rod (going down to trans), gets activated properly.
That's all I can tell from the photo with my old eyes
Jim
Kahuna is offline   Reply With Quote
Old 11-20-2018, 12:11 PM   #25
KULTULZ
KULTULZ's Avatar
Question Re: New to 312 Y Block
Again, the definition of a$$-u-me ...
Old 11-20-2018, 12:27 PM   #26
Kahuna
Kahuna's Avatar
OK, 99 & 9/10% sure?
ha ha
Jim
Old 11-20-2018, 01:20 PM   #27
KULTULZ
KULTULZ's Avatar
Cool Re: New to 312 Y Block
ha ha
Jim
Might as well go for the GOLD TROPHY ...
Old 11-20-2018, 01:53 PM   #28
40 Deluxe
CrazyTed, could you crawl under your car and snap and post a picture of the vacuum modulator on the back of the trans? Hopefully this will end the endless speculation about what trans you have! Thanks.
Old 11-20-2018, 02:39 PM   #29
KULTULZ
KULTULZ's Avatar
Wink Re: New to 312 Y Block
OH CrazyTed ?
Would this setup look any nicer to you? It will also operate a FOM -
File Type: jpg Throttle Linkage - 1956 BIRD w ECZ-B - H4160 - FOM.jpg (107.3 KB, 132 views)
Old 11-20-2018, 02:44 PM   #30
40 Deluxe
Originally Posted by KULTULZ View Post
OH CrazyTed ?
Is that an overdrive relay I see on the firewall?
Old 11-20-2018, 04:44 PM   #31
KULTULZ
KULTULZ's Avatar
What I was trying to get across was the use of a 55/56 bracket on a ECZ-B. Both ST and AT transmission brackets are similar in appearance.
It may be that this setup would be more pleasing to the OP's eyes.
Old 11-20-2018, 07:27 PM   #32
rotorwrench
rotorwrench's Avatar
I'm not sure an FMX will fit a Y-block. They had FOM and COM transmissions back in the day but the FMX is a bit different. It's is a cross between the FX small case and MX medium case Cruise-O-Matics. Sort of the best of both worlds.
Old 11-20-2018, 08:28 PM   #33
40 Deluxe
I'm thinking (maybe just assuming) that a Y-block Fordomatic bell housing will bolt to a FMX case.
Old 11-20-2018, 09:08 PM   #34
Y-Blockhead
Y-Blockhead's Avatar
Yes the FMX can mate to a Fordo bell housing with a few modifications. I also used a FMX torque converter.
I used Lokar cables for throttle and kickdown. That was a few years ago. Now I am running a C-4 with a Gear Vendor. Still using the same cable setup tho.
Nice looking car CrazyTed...
Old 11-20-2018, 09:52 PM   #35
miker98038
miker98038's Avatar
Sorry to drift OT, but,
“ Now I am running a C-4 with a Gear Vendor.”
Now that has to be a sweet combo. Great looking set up.
I think the Hoosier Hurricane has a number of post over at yblocksforever regarding the FMX/Yblock conversion.
miker98038 is offline   Reply With Quote
Old 11-21-2018, 07:18 PM   #36
rotorwrench
A lot of stuff is adaptable between all of the Borg Warner designs. Folks used to adapt COM parts with FOM parts to get a dual range shift. I'm not surprised that the FMX can fit in the mix even though it has more than one tail shaft type. I hear that those 58 to 62 COM/Y-Block transmissions are getting harder to source. The bell housing is a must for conversions. I think I'd look into an AOD transmission since it is based on the FMX and has the overdrive. That would be worlds better than just a 3-speed with 1 to 1 final drive. It would make it worth the effort for certain. This is a link to some info on an adapter kit. http://www.secondchancegarage.com/public/277.cfm
Old 11-21-2018, 08:27 PM   #37
40 Deluxe
Plus, with the AOD you get overdrive and lockup converter without any electrical/electronics whatsoever!
Old 11-23-2018, 12:06 PM   #38
KULTULZ
KULTULZ's Avatar
OK ...
Just to clear-up my original post regarding 55/56 throttle linkage use on a 57 intake (the photo showing OD linkage), here is a photo just recently posted on the other forum showing a 55 BIRD with an ECZ-B intake using the original 55 throttle linkage. One other poster in the same thread said his bracket install needed to be shimmed.
Old 11-24-2018, 12:35 AM   #39
slumlord44
The FMX came out in '58 or '59 for sure. Dad's '59 had an FMX for sure. The C6 came out in '66 and won't fit the Y block. The FMX will fit with the right parts.
slumlord44 is offline   Reply With Quote
Old 11-24-2018, 07:39 AM   #40
KULTULZ
KULTULZ's Avatar
The FMX was introduced in the 1968 model run. FORD acquired BW design rights and put the MX internals into the FX main case and deleting the rear pump.
The CRUISE-O-MATIC (market name designation) DUAL RANGE SERIES (FX - MX - HX) was introduced on the 1958 model run. The FORD-O-MATIC was retained for certain models and the F/M/2 was introduced in the 1959 model year. The modulator valve was incorporated in the 1961 model year, eliminating the TV shift control.
