11-03-2016, 10:03 AM | #1 |
1938 Tonner Pedal Linkage questions
Can anyone help me with some details or photos to locate where the stop switch and chain(if applicable) are supposed to be located on a 1-ton 1938 truck with cable brakes? I have found info on the pass cars and 1/2 tons but nothing for big trucks.
Also looking for the correct length and location to hook the clutch pedal return spring on the chassis of the same 1-ton truck. I've seen the short spring direct to the close crossmember and I've seen springs that pass through 1 crossmember to hook to the second. Getting really close now!Thanks. |
11-03-2016, 11:46 AM | #2 |
Re: 1938 Tonner Pedal Linkage questions
I don't know if this will help but in the green parts book under the stop light switch
the next item is bolt #24324-S7. It states Bolt (stop light switch to pedal bracket). So maybe the switch is bolted to the bracket. Bob |
11-03-2016, 12:01 PM | #3 | |
11-03-2016, 02:03 PM | #4 |
I believe the big trucks may have had them attached to the side of the transmission. Does anyone have a photo of that part? Or a photo of your big truck transmission? |
