Old 10-31-2019, 09:57 AM   #1
kirkf
kirkf's Avatar
Default Headbolts
Why do some flathead headbolts have an H on the head, and some have an S on the top? (These are Canadian Flatheads)
I've come across both, on various engines.
Regards,
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 10-31-2019, 11:32 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Headbolts
Likely identifies Fords sources.
Russ/40 is offline   Reply With Quote
Old 11-04-2019, 03:06 PM   #3
kirkf
kirkf's Avatar
Really?
No one has a definitive answer as to why headbolts can have either an 'S' or an 'H' on the head?
My trust in the Fordbarn as the ultimate pool of old timer knowledge is deeply shaken...
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
Old 11-04-2019, 05:06 PM   #4
Mart
Mart's Avatar
The most likely answer was given. Bolts supplied to Ford from alternative suppliers. Not definitive, but most likely. There shouldn't be any physical difference between them. It's not like Using one type over another is an ancient speed secret.
Old 11-04-2019, 05:10 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
At the time there were two different suppliers for the bolts.
One was located in Hamilton Ontario and the other in Stratford Ontario.
Thus the H and S
Old 11-04-2019, 05:25 PM   #6
Ronnie
Ronnie's Avatar
Originally Posted by kirkf View Post
really?
No one has a definitive answer as to why headbolts can have either an 's' or an 'h' on the head?
My trust in the fordbarn as the ultimate pool of old timer knowledge is deeply shaken...
Kirk
wow
R
Ronnie is offline   Reply With Quote
Old 11-04-2019, 05:32 PM   #7
oldford2
oldford2's Avatar
Really?
Kirk
Kirk, you need to be a little patient before you rip the Barners.
You got your answer
oldford2 is offline   Reply With Quote
Old 11-04-2019, 05:54 PM   #8
kirkf
kirkf's Avatar
Clearly the humour intended in my post didn't translate well to text.
I'll try harder next time.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
Old 11-04-2019, 06:22 PM   #9
frnkeore
frnkeore's Avatar
You gotta remember, old men, don't usually get nicer as time rolls by
Always keep in mind that old age and treachery, beat youth and skill
I used to be young, I know about it!
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 11-04-2019, 06:37 PM   #10
Mart
Mart's Avatar
I did assume your reply was tongue in cheek. A winky smily emoticon would have helped.
