Old 05-22-2013, 03:28 PM   #1
Randall
Randall's Avatar
Default 32 Roadster Steering
I just started working on steering box,I have two, or so I thought, anyway one has steering shaft .885and the other .758 dia., both have drop column with key and steering lock,think one could be a sedan? Thanks
Randall is offline   Reply With Quote
Old 05-22-2013, 03:46 PM   #2
xix32
Default Re: 32 Roadster Steering
The .885" is from a "BIG" truck.
the column drop seems to be the same. But the tube has thicker material wall thickness, so the I.D. is smaller and won't fit on a passenger car box.
the pitman shaft is also a bigger diameter, so it won't fit through the car frame.
Also the mount flange is "clocked" different, so it won't work in a car.
xix32 is offline   Reply With Quote
Old 05-22-2013, 03:55 PM   #3
Randall
Randall's Avatar
xix32 Thanks!
Old 05-23-2013, 04:46 AM   #4
Bobs32
Bobs32's Avatar
The steering in my 32 Roadster is from a 50 ford truck.
Bobs32 is offline   Reply With Quote
